Modbus RTU obtaining sporadic values or missing/skipping entirely
I have recently connected two Carrier chillers (unit ID: 32 and unit ID 6) via Modbus RTU to a Pi running Node-RED. The physical wiring is shown below. This is RS485 to USB adapter that I am using.
My flow is quite simple and attached here. I am polling both units using one inject node every 60 seconds and trying to get 3 values from each chiller ( addresses 16393,16394, 16395, which correspond to setpoint, entering fluid temperature, and leaving fluid temperature.
Below is a plot from Grafana showing the irregular nature of the readings. Sometimes Chiller 6 has no readings (underlined in red), while Chiller #32 does. I reversed my nodes (so that it would poll #6 first, then #32), and found the opposite in Grafana, i.e. there would be "gaps" in #32's data.
Other times, it seems the modbus data is completely skipped (you should see 10 dots in each 10 minute interval, and you can see usually 1 or more is missing, as underlined in yellow).
[{"id":"8760ce25e90c533a","type":"modbus-flex-getter","z":"6c39e39024574678","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"9ab875472411c19f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":510,"y":100,"wires":[["c98b1d1c3bbdca4e"],[]]},{"id":"586eae9839f9f12a","type":"function","z":"6c39e39024574678","name":"Chiller 6","func":"msg.topic = \"chiller_6\"\n\nmsg.payload = {\n    value: msg.payload,\n    'fc': 4,\n    'unitid': 6,\n    'address': 16393,\n    'quantity': 3\n}\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":100,"wires":[["8760ce25e90c533a"]]},{"id":"5f2dde25fa1ad10e","type":"inject","z":"6c39e39024574678","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":40,"wires":[["1f5725f199c175c9"]]},{"id":"c98b1d1c3bbdca4e","type":"debug","z":"6c39e39024574678","name":"chiller_6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":720,"y":100,"wires":[]},{"id":"2a45711de6cd2c91","type":"modbus-flex-getter","z":"6c39e39024574678","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"9ab875472411c19f","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":530,"y":40,"wires":[["485a1917dc1cb621","586eae9839f9f12a"],[]]},{"id":"1f5725f199c175c9","type":"function","z":"6c39e39024574678","name":"Chiller 32","func":"msg.topic = \"chiller_32\"\n\nmsg.payload = {\n    value: msg.payload,\n    'fc': 4,\n    'unitid': 32,\n    'address': 16393,\n    'quantity': 3\n}\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":40,"wires":[["2a45711de6cd2c91"]]},{"id":"485a1917dc1cb621","type":"debug","z":"6c39e39024574678","name":"chiller_32","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":740,"y":40,"wires":[]},{"id":"9ab875472411c19f","type":"modbus-client","name":"","clienttype":"serial","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU","serialBaudrate":"19200","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"2000","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"","commandDelay":50,"clientTimeout":2000,"reconnectOnTimeout":false,"reconnectTimeout":2000,"parallelUnitIdsAllowed":false}]
Is anyone aware of some tweaks to the settings that I can make to get some repeatability here? I do not have to poll every 60 seconds. It could be every 90 seconds, but I do not think that is the problem.
Thanks in advance.
Edit the debug nodes to output to the console, so they will output to the node red log. Then when you see missing data in grafana go back and look in the log at that time and see what you see in the debug nodes.
Or install the Flogger node and put the output to that also
Also have you checked for correct termination on the bus ?
Craig
