Modbus TCP float to value
In case you don't know then you can import a flow from here using the menu Import feature.
If you didn't know that then I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
