Hi everyone,
I have a ModBus register of 2 words in Float32. I can't convert it to decimal to import it into InfluxDB.
I can't config the Buffer Parser...
Help please
Hi everyone,
Help please
Have a look to this link. Hope this helps.
https://www.unipi.technology/case_study/sending-temperatures-from-unipi-gate-to-a-thingsboard-cloud-392
Here :
[1,65472]
Except that the Getter ModBus does not deal with Float32 I think because I have two arrays... I don't understand anything anymore...
Generally, I have these values coming up when I should have 50Hz stable.
I cant help if you dont do what I ask.
That's what I did. There are two exits from the getter. Here they are:
First output :
[6554,65472]
Second output :
{"data":[6554,65472],"buffer":[25,154,255,192]}
Still no dice.
you are clicking the copy button while hovered on the payload
you need to click the button top most (the one by itself ) - like in the picture
Here you go ![]()
Please forgive me, I am a novice....
First output :
{"topic":"b08c8b03.0ab7d8","messageId":"60a65c428f2c51a43672ee90","payload":[9700,65472],"queueLengthByUnitId":{"unitId":2,"queueLength":0},"queueUnitId":2,"unitId":2,"modbusRequest":{"value":1621515330131,"unitid":"2","fc":3,"address":"3110","quantity":"2","messageId":"60a65c428f2c51a43672ee90"},"responseBuffer":{"data":[9700,65472],"buffer":[37,228,255,192]},"_msgid":"587c6c81.d54b34"}
Second output :
{"topic":"b08c8b03.0ab7d8","messageId":"60a65c428f2c51a43672ee90","payload":{"data":[9700,65472],"buffer":[37,228,255,192]},"queueLengthByUnitId":{"unitId":2,"queueLength":0},"queueUnitId":2,"unitId":2,"modbusRequest":{"value":1621515330131,"unitid":"2","fc":3,"address":"3110","quantity":"2","messageId":"60a65c428f2c51a43672ee90"},"values":[9700,65472],"_msgid":"587c6c81.d54b34"}
So those values are weird. Do you have a manual - I suspect they are not straight forward float32 values.
also, what registers are you accessing in the modbus node (show picture)
Yes, it is an IEM 2150 counter : https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=7EN02-0361-00.pdf&p_Doc_Ref=7EN02-0361
I would like to know the 3054 register
Set the modbus node to read from address 3000 & quantity to 77
This will return 77 INT16 values (154 bytes)
Add the below buffer parser (ctrl+i) to your flow and attach it to the top output
[{"id":"e61cc957.8e5ee8","type":"buffer-parser","z":"4b3f21a3.ba434","name":"","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"current","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"voltage","offset":56,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"activePower","offset":108,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"reactivePower","offset":136,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"apparentPower","offset":152,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1350,"y":2540,"wires":[["cb923bba.971898"]]}]
What this will do is ...
[val_of_3000,val_of_30001,etc,etc,etc])Buffer in msg.responseBuffer.buffer - we will access these in the buffer parser
msg.payload.current (see image below for ref)msg.payload.voltage (see image below for ref)Why...
//for reference
Ok, thanks for your reply !
But, the response of the Buffer Parser is :
RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 0. Received 56
Here the flow :
[{"id":"46d3f8ff.5cfc08","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b08c8b03.0ab7d8","type":"modbus-getter","z":"46d3f8ff.5cfc08","name":"","showStatusActivities":true,"showErrors":false,"logIOActivities":false,"unitid":"2","dataType":"HoldingRegister","adr":"3000","quantity":"2","server":"111e1e7d.08f902","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":420,"y":300,"wires":[["e61cc957.8e5ee8"],[]]},{"id":"55d05965.f27718","type":"inject","z":"46d3f8ff.5cfc08","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":300,"wires":[["b08c8b03.0ab7d8"]]},{"id":"e61cc957.8e5ee8","type":"buffer-parser","z":"46d3f8ff.5cfc08","name":"","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"current","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"voltage","offset":56,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"activePower","offset":108,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"reactivePower","offset":136,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatbe","name":"apparentPower","offset":152,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":670,"y":300,"wires":[[]]},{"id":"111e1e7d.08f902","type":"modbus-client","name":"","clienttype":"serial","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU","serialBaudrate":"19200","serialDatabits":"8","serialStopbits":"1","serialParity":"even","serialConnectionDelay":"100","unit_id":10,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true}]
You are requesting 2 registers from modbus...
... 2 registers is == 4 bytes
The buffer parser is set to parse multiple values (current, voltage, etc) from ...
If you want this to work, you need to grab all the registers in one go as described...
Hi Steve,
I found the solution by chance. I turned the buffer parser around until I found my expected value.
I also called Schneider Electric who pointed out an error in the calculation note: all values in Float32 are expressed in Kilo.
Moreover, the MSB must be switched to the left for reading.
Here is the flow:
[{"id":"bc264764.dff808","type":"buffer-parser","z":"f92e921.524f77","name":"Float 32 to Dec","data":"responseBuffer.buffer","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Puissance (Wh)","offset":0,"length":1,"offsetbit":0,"scale":"1000","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":380,"y":120,"wires":[["f704a034.13002"]]}]
So simple and so complicated at the same time !
Thanks for your involvement and I hope others can be helped!
