Convert 2 modbus words to float
Hi folks,
I'm trying to convert 2 words in a ModbusTCP read, to a float value.
Using node-red-contrib-buffer-parser, I'm not able to convert to float.
This is what I get in Modbus read:
[ 16888, 1049 ]
I don't understand how to configure buffer parser node.
Help me please.
Hello ..
If you wire a complete msg Debug node to the output of your Modbus-Flex-Getter
you'll get a msg structured like below that includes the buffer data for Buffer-parser to use for the conversion
Copy paste a sample of the data and tell us what real values it should be
You can feed the 16bit integer values into buffer parser ...
BUT, as @UnborN points out, you should use the actual buffer
Then configure the buffer parser as so...
be sure to read the built in help...
