Modify msg object
I am trying to modify the msg object. Take this msg for example.
object
type: "status"
client: "0x4DE0E196"
topic: "transmit"
payload: object
freq: 7.2897
lo: 100
hi: 2900
tx_filter_changes_allowed: 1
_msgid: "c5438637a2d2e1fe"
I want to remove the payload from the message into a new object and do a Object.assign with a new object to the payload. Then insert the new object into the msg. I have no issues adding msg.payload to a variable and performing the Object.assign to insert the new object. The problem is when that when I do a delete msg.payload the type, client and topic objects are deleted as well. Since the objects that precede the payload change I can't hard code that.
Is there any way to delete the payload while preserving the rest of the objects?
Regards
Post deleted
@jbudd
Of that I have no doubt...
Yes I should have called them properties, however the entire msg is a object. I tested this by running a simple function that does
msg = delete msg.payload
return msg
when I do this the only output I get is a Boolean value of true. I assumed that the properties that are not in the payload would still be available. The idea is to
let band = "band: 40"
let Obj = msg.payload
let newObj = delete.msg.payload
Obj = Object.assign(band, Obj)
return Object.assign(newObj, Obj)
This would allow me to place the band property at the beginning of the msg.payload and then add to the newObj which would have the other properties.
Since the properties are not an object as you stated then I think this may be where I am going off track. When I did this I got the properties in the Obj variable but not the newObj properties.
So the question then is how can I strip out the properties that are not in the payload into an object?
Post deleted since you are not paying attention.
This doesn't make sense. First of all, delete.msg.payload indicates you have an object called "delete". However delete is a keyword. If you want to do the action to delete something, make sure to have space afterwards! Further, with equals you indicate you want to save the output of the delete action into newObj. But a delete action doesn't return anything. It deletes the data. That is not something you can save in a new variable.
Also, you use Object.assign to try to merge a string with an object? That won't work. You can read more about it here:
Object.assign() - JavaScript | MDN
I would recommend starting with simpler things and perhaps stay away from Object.assign as it is more advanced.
Can you explain what you have as input and what you would have as output? The more exact details on incoming object and structure of the output you want, the better feedback I can give.
I would recommend playing around with javascript first, for example here:
JavaScript Playground
If you try this code, you will clearly see how delete works:
const msg = {
  band: "band: 40",
  payload: {
    foo: "bar"
delete msg.payload;
console.log(msg)
If you paste that code into the link provided, it will print out for you msg object without payload, as it has been successfully deleted.
I got it to work with..
let obj = msg.payload
    delete msg.payload
    const BAND = { band: band }
    const newPayload = { payload: Object.assign(BAND, obj)}
    const payload = Object.assign(msg, newPayload)
    return payload;
Now I get
object
type: "status"
client: "0x41372A88"
topic: "slice/0"
_msgid: "a54a306f1a173263"
payload: object
band: 80
RF_frequency: 3.8103
wide: 0
lock: 0
Regards
Allright, indent is a bit off and semi-colon usage is inconsistent, but at least it works so congrats! I'd still lay off Object.assign as I have yet to see a good place to use it and for this level of coding it will most likely just make things more complicated. It's hard for me to understand what's going on.
Why can't you simply do:
msg.payload.band = band; // assuming `band` is a variable that already exists in your scope
I noticed you mentioned you wanted band property at the beginning of msg.payload. But if msg.payload is an object, javascript objects are really maps and more specifically unordered. So you can't order props inside an object. If you need ordered properties, you must use array (or possibly ordered maps, but that's more of an advanced topic). Further, you want to strip out the properties not in payload? Why not use delete msg.payload? I noticed you extract payload into variable called Obj, but then later add that payload back into msg? What's the point of stripping it out if you just gonna put it back in?
That is because I just did a copy paste. It is properly formatted in the object.
Why not use delete msg.payload ?
    delete msg.payload
I did...
Here is where I prepend the band object to the beginning of the vari obj. The next step is to apend the var obj to msg where payload was deleted. This way the payload does not show up twice.
If I use msg.payload.band it works but it appends the object to the end of the payload. The goal was to prepend it to the payload. It's not as efficient as msg.payload.band but I wanted to use Object.assign to prepend it.
I could use array.unshift or array.push but then I have to convert it back to an object. I don't know if that actually less cpu that the Object.assign and once I went down that road I was determined to make it happen.
I will now go back and try array.unshift / array.push for fun.
Regards
Why do you care what order the properties are in?
At the end of the day it does not matter. At 1st I felt it was better represented as the 1st property. When I was struggling to get it to to work then it became a goal to make it happen. Node-RED was my 1st look into JavaScript and it is as much a learning experience as it its a means to an end.
Ok all of this is to attempt to modify the order of a javascript object. That is futile and you're working uphill from here. An object in javascript is essentially a map with string keys, effectively unordered in practice but as you discovered it retains insert order. It is not designed for what you want. If you really needed order, there are more advanced options: @js-sdsl/ordered-map - npm
Well I got it to work and learned a couple of things. I call that a win. Thanks for your time.
Regards
As others have said ordering the properties of an Object is mostly a waste of time. However, a little while ago someone here had a similar request so, just for educational & interest you understand, I looked at ways of achieving sorted properties of an Object. These are two functions I came up with (note: I probably found them as a proposal by someone a lot cleverer than I am);
    * Description.  Get the 'keys' of the Object and sort them ('Alpha' sort)
    *               Create a new Object, by adding the properties of the old Object in order of the sorted 'keys'
    * @param    {Object}        object      The object to operate on
    * @return   {Object}                    An Object with the properties in 'key' alphabetical order
    * @Example let sortedObject = sortObjectProperties({c: 1, a: 2, b: 1}) becomes {a: 2, b: 1, c: 1}
    function sortObjectProperties (object) {
        let newObject = {}
        Object.keys(object).sort().forEach((key) => newObject[key] = object[key])
        return newObject
    } // End Function sortObjectProperties()
    * Description.  Create a new Object, by adding the properties of the old Object in order of the Array of 'keys'
    *               If required, add any remaining properties of old Object to new Object
    * @param    {Array}         keysInOrder     An Array of the keys required, in order to be added
    * @param    {boolean}       addAll          True if all properties of old Object to be added to new Object, false if only keys
    *                                            in Array to be added
    * @return   {Object}                        An Object with the properties in 'key' order of the provided Array, plus any other properties in
    *                                            original order
    * @Example let orderedObject = orderObjectProperties({c: 1, a: 2, b: 1}, ['a', 'b'], false) becomes {a: 2, b: 1}
    function orderObjectProperties(object, keysInOrder, addAll = true) {
        let newObject = {}
        // Add the new Object properties in order of 'key' in array
        for (const key of keysInOrder) {
            if (Object.keys(object).includes(key) && !Object.keys(newObject).includes(key))
        // Add any old Object properties not yet added, if required
        if (addAll) {
            for (const key of Object.keys(object)) {
                if (!Object.keys(newObject).includes(key))
         return newObject
    } // End Function orderObjectProperties()
As you can see both functions return a new Object which allows maintaining the original.
Have fun.
I normally do it someting like this in a function node.
let newMsg = {};
newMsg.originalPayload = msg.payload;
newMsg.topic = *your new topic*;
newMsg.payload = *build your new payload here*;
newMsg.anotherProperty = 12345;
return newMsg;
