I'm using a node to execute a Python script with a spawn process and I'm reading stdout during execution. I would like to see the output in the debug window, which works fine if I send everytime a message when my child.stdout.on() function gets triggered. But I don't want to send for every line a new message, I would like to use it in a way, that I just send one time a message and when more data is coming I just append the already sent message.
My idea is, to write all the output in a context variable and use a setInterval function which is reading that context variable and refreshing the msg.payload. But the content in the debug window doesn't change after refreshing msg.payload, only if I send a new msg I see the updated content.
JS file:
var child = spawn('python3', [node.py_path, node.sys_cfg]);
child.stdout.on('data', function(data) {
console.log(data.toString());
proc_data = globalContext.get("at_arr");
proc_data += data.toString();
globalContext.set("at_arr", proc_data);
HTML file (proposal which doesn't work currently):
window.setInterval(function() {
//var globalContext = this.context().global;
//var data_str = globalContext.get("at_arr");
//msg.payload = data_str;
//document.getElementById("msg").innerHTML = msg.payload;
}, 1000);
</script>
Any idea how to modify the msg.payload after sending the msg?
