Changing message properties
Hi!
I have an exec node that run a python script, my python script has a while structure that sends several data once every 1 second, and the payload message that I receive isn't the same, and the payload name property is the same, so, how can I change the payload name property?
Now I am receiving the following data:
payload: "Date: 2018/07/23 16:38:49 -- Speed: 0 kph".
payload: "Date: 2018/07/23 16:38:49 -- Gas Level: 90%".
I want to change the first payload name to "payload.speed", and the second to "payload.gaslvl" and so on, like the following examples.
payload.speed: "Date: 2018/07/23 16:38:49 -- Speed: 0 kph".
payload.gaslvl: "Date: 2018/07/23 16:38:49 -- Gas Level: 90%".
payload.rpm ...
How can I solve this?
take a look at the change node or do it in a function node after your exec node.
But most nodes expect the important data to be in msg.payload so you might find there are issues if you are attaching further nodes
That can be achieved with switch and change nodes. Below code will produce:
r-01
Flow:
[{"id":"a2e8b28c.0ceb4","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"b325c167.3cc55","type":"inject","z":"a2e8b28c.0ceb4","name":"speed","topic":"speed","payload":"Date: 2018/07/23 16:38:49 -- Speed: 0 kph","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":160,"wires":[["fe111fea.f6642"]]},{"id":"af3463f6.fab3f","type":"change","z":"a2e8b28c.0ceb4","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.speed","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":160,"wires":[["53460eaf.2830d"]]},{"id":"fe111fea.f6642","type":"switch","z":"a2e8b28c.0ceb4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Speed","vt":"str"},{"t":"cont","v":"Gas Level","vt":"str"},{"t":"cont","v":"rpm","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":370,"y":200,"wires":[["af3463f6.fab3f"],["7cbf68a.ac0eb98"],["b4a5708a.7c78c"]]},{"id":"7cbf68a.ac0eb98","type":"change","z":"a2e8b28c.0ceb4","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.gaslvl","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":200,"wires":[["de46d686.4c6df8"]]},{"id":"b4a5708a.7c78c","type":"change","z":"a2e8b28c.0ceb4","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.rpm","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":240,"wires":[["eaf846cd.41b418"]]},{"id":"53460eaf.2830d","type":"debug","z":"a2e8b28c.0ceb4","name":"speed","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":790,"y":160,"wires":[]},{"id":"de46d686.4c6df8","type":"debug","z":"a2e8b28c.0ceb4","name":"gaslvl","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":790,"y":200,"wires":[]},{"id":"eaf846cd.41b418","type":"debug","z":"a2e8b28c.0ceb4","name":"rpm","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.rpm","x":790,"y":240,"wires":[]},{"id":"166f93fd.c9e6bc","type":"inject","z":"a2e8b28c.0ceb4","name":"gaslvl","topic":"gaslvl","payload":"\"Date: 2018/07/23 16:38:49 -- Gas Level: 90%\".","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":220,"wires":[["fe111fea.f6642"]]}]
Or, by moving the properties up 1 level to msg.speed, msg.gaslvl with 1 change node:
[{"id":"d605f6dc.c15438","type":"debug","z":"71dfb460.a1afbc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":570,"y":380,"wires":[]},{"id":"9fc6ee1c.a04a2","type":"inject","z":"71dfb460.a1afbc","name":"","topic":"","payload":"Date: 2018/07/23 16:38:49 -- Speed: 0 kph","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":360,"wires":[["18435e7b.448a92"]]},{"id":"14a96805.6fb558","type":"inject","z":"71dfb460.a1afbc","name":"","topic":"","payload":"Date: 2018/07/23 16:38:49 -- Gas Level: 90%","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":400,"wires":[["18435e7b.448a92"]]},{"id":"18435e7b.448a92","type":"change","z":"71dfb460.a1afbc","name":"","rules":[{"t":"set","p":"speed","pt":"msg","to":"$contains(payload, \"Speed\") ? payload : \"\"","tot":"jsonata"},{"t":"set","p":"gaslvl","pt":"msg","to":"$contains(payload, \"Gas\") ? payload : \"\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":380,"wires":[["d605f6dc.c15438"]]}]
Screenshot%20at%202018-07-25%2016-00-42
Thank you for your help! It solve my problem.
Thank you for your help ghayne!
Thank you ukmoose for your help ^^
