Change node not working as I expected
Hi I am trying to recreate the following format
object
topic: "owl"
payload: object
IP: "27"
so I understand that to get the IP from this result I would access msg.payload.IP fine!
But how do I recreate the input to produce this result
I have a function node with msg.payload="27" then I have a change node with set msg.payload.IP to msg.payload but it doesn't create the payload:object or the IP what am I doing wrong.
You first used msg.payload to store a string, and that is fine. Then you want to use msg.payload to be an object with property IP. Indeed, that is not possible. You can not add properties to a string.
A simple solution is to delete msg.payload in the change node, as shown below:
r-01
or alternatively:
r-02
I thought that Move msg.payload to msg.payload.ip would work but not at my pc so can't check.
Hi Colin,
Indeed, and this would be the best choice, in my opinion :slight_smile:
r-03
Yep that's sorted it thanks
