I have this issue i can't make the CHANGE node "SET" a sub msg name like "msg.payload.brightness" it works with "msg.brightness".
can't either move anything to "msg.payload.brightness".. is it a new thing? or me ;-).
anything else with CHANGE node works..
does i need to make a function to do this?
It will depend on what msg.payload is to begin with.
If its an Object, then you can set any properties you want on it.
If its a String or a Number, you cannot set properties on it - a JavaScript restriction.
So the question is what is your msg.payload set to when its passed to the Change node?
ohh okay thanks for clarifying..
