Module error node-red
how do I format my node-red and fix this error?
i'm new to node-red, how do I format and reinstall again
Just follow the instructions again - no need to uninstall.
https://nodered.org/docs/getting-started/windows
PS, I recommend node-js version 14 LTS
the problem is that I can't use any 'npm' command, it looks like the flood from the same message above
no 'npm' command works
Did you install it as it says in the directions?
https://nodered.org/docs/getting-started/local
Try reinstalling it... (as per Node-Red for Windows)
Opps, @zenofmud beat me too it :slight_smile:
i tried to install but i can't delete node_modules at all
It looks like you have corrupted node_modules.
Completely remove node and node_modules ...
HOW TO: How to completely remove node.js from Windows - Stack Overflow
THEN - install node-js V14 LTS
THEN - install node-red again...
thank you very much!
