Module install issue
Hello I am new to node red. I am trying to used modbus to communicate from a wago plc to Node-red I can not install the modbus anything on the palette. I am using a windows 10 64-bit computer. Everything I see is geared to Linux fixes. I am not that good with Linux so I am struggling.
This is not the only module it wont install but it is the in
Below is the error it gives me in the cmd that is running node-red.
[2020-07-02 15:48:32.702] [INFO] NodeRed FlowManager - Finished setting node-red nodes successfully.
2 Jul 15:48:32 - [info] [tcp in:6e41a71c.528b98] listening on port 502
2 Jul 15:49:02 - [info] [debug:Wago_input] undefined
2 Jul 15:49:08 - [info] Installing module: node-red-contrib-modbus, version: 5.13.3
2 Jul 15:49:14 - [warn] Installation of module node-red-contrib-modbus failed:
2 Jul 15:49:14 - [warn] ------------------------------------------
2 Jul 15:49:14 - [warn] prebuild-install WARN install No prebuilt binaries found (target=14.5.0 runtime=node arch=x64 libc= platform=win32)
gyp ERR! find VS
gyp ERR! find VS msvs_version not set from command line or npm config
gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
gyp ERR! find VS checking VS2019 (16.6.30225.117) found at:
gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2019\Community"
gyp ERR! find VS - "Visual Studio C++ core features" missing
gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
gyp ERR! find VS looking for Visual Studio 2015
gyp ERR! find VS - not found
gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
gyp ERR! find VS
gyp ERR! find VS **************************************************************
gyp ERR! find VS You need to install the latest version of Visual Studio
gyp ERR! find VS including the "Desktop development with C++" workload.
gyp ERR! find VS For more information consult the documentation at:
gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
gyp ERR! find VS
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Visual Studio installation to use
gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
gyp ERR! stack at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
gyp ERR! stack at ChildProcess.exithandler (child_process.js:315:5)
gyp ERR! stack at ChildProcess.emit (events.js:314:20)
gyp ERR! stack at maybeClose (internal/child_process.js:1051:16)
gyp ERR! System Windows_NT 10.0.18363
gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\adhei.node-red\node_modules\modbus-serial\node_modules@serialport\bindings
gyp ERR! node -v v14.5.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! C:\Users\adhei\AppData\Roaming\npm-cache_logs\2020-07-02T20_49_14_102Z-debug.log
This is not a Linux thing. Your pc simply doesn't have the necessary components installed to compile something that needs compiling.
This is the giveaway...
See this
Just to add to Steve's reply, the log does include a description of what you need to do:
Steve_McI,
I have Visual studio 2019 installed and before that was 2017. I have programmed in the visual studio 2017 so I know it was working.
You still have to run the command. Not sure what it does under the hood (likely some node js bindings) but installing Vs is not enough.
It worked. I have been fighting with this for last 3 days.
Thanks a bunch.
