why does
let time = moment().tz("Europe/Berlin").format("HH:mm:ss");
work in a function node on Node-Red 3.1.0
and
not work in a function node on Node-Red 3.1.3
Problem seems to be that moment() is not accessible
why does
and
Just a reminder that you do not need moment for that. Use the standard INTL library instead.
Just a little trail for unified Name Space ![]()
[{"id":"c3225306b3694491","type":"function","z":"e973a865c2b93001","name":"function 163","func":"let x = {\n \"$schema\": \"Enterprise/Site/Line1/StationA/measurements/_schema\",\n \"title\": \"Measurement Schema for StationA\",\n \"type\": \"object\",\n \"properties\": {\n \"value\": {\n \"description\": \"Temperatur\",\n \"type\": \"number\"\n },\n \"unit\": {\n \"description\": \"The unit of the measurement value\",\n \"type\": \"string\"\n },\n \"timestamp\": {\n \"description\": \"The timestamp of the measurement in ISO 8601 format\",\n \"type\": \"string\"\n }\n },\n \"required\": msg.payload\n}\nreturn {payload:x};","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":260,"wires":[["55146e0d9a4f4c61"]]},{"id":"8aa8656cbb2aee55","type":"inject","z":"e973a865c2b93001","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"50.55","payloadType":"num","x":170,"y":260,"wires":[["3e28fb8fde6e0f72"]]},{"id":"55146e0d9a4f4c61","type":"debug","z":"e973a865c2b93001","name":"debug 2508","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":260,"wires":[]},{"id":"3e28fb8fde6e0f72","type":"function","z":"e973a865c2b93001","name":"time","func":"let time = moment().tz(\"Europe/Berlin\").format(\"DD-MM-YYYY @ HH:mm:ss\");\nreturn { payload: [msg.payload, \"celsius\", time] };","outputs":1,"timeout":"","noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nif (context.get(\"counter\") === undefined) {\n context.set(\"counter\", 0);\n}","finalize":"","libs":[{"var":"moment","module":"moment"},{"var":"momentTimezone","module":"moment-timezone"}],"x":310,"y":260,"wires":[["c3225306b3694491"]]}]
