Using Moment.js in a function node - NR 3.01 - 2023?
Guys
What is the state of the nation in terms of using Moment.js in a function node as of NR 3.01 and 2023 ?
I believe that Moment.js is now included with NR due to support in the change node/jsonata etc.
What is the method therefore for calling moment in a function node for dat and time formatting ?
Having done a search on this already it appears that the solution has evolved over time and am unsure if i need to install the NPM module now, make the addition to settings.js etc - or if i can happily just declare it at the top of my function and away i go ?
Craig
You have to include it in the Setup tab of any Function node you want to use it
Example of formatting today's date
msg.payload = moment().format("YYYY-MM-DD HH:mm:ss")
If an npm package is already in .node-red/node_modules, possibly because it was installed by another node, Node-red will use that when you add it in a Function's Setup tab .. if its missing it will automatically install it.
In settings.js there is the following settings to allow or deny this functionality.
  /** Allow the Function node to load additional npm modules directly */
  functionExternalModules: true,
You can also use JSONata in a function node - which already includes Moment of course.
I think $moment() was added to jsonata by Node-red but only available in the Change node.
The jsonata library by itself natively doesnt have it as function.
but even so .. if someone would resort to using a Function node, it means they have some knowledge of JS and i doubt they would be using jsonata which as demonstrated in some posts is a bit slower than plain JS.
It's OK because it looks like I made up that fact anyway! I was convinced that JSONata had been added as a function to function nodes but I can't find any references to it at all.
Do you mean these?
evaluateJSONataExpression
prepareJSONataExpression
it works .. Interesting, never knew those existed :wink:
const expression = '$moment().format("YYYY-MM-DD HH:mm:ss")';
let exp = RED.util.prepareJSONataExpression(expression, node)
RED.util.evaluateJSONataExpression(exp, msg, (err, res) => {
    node.send({ payload : res})
Grrr :grin: well found. Added to my Obsidian knowledgebase as it should have been before.
Well hidden indeed.
thanks for chiming in everyone - hopefully all of that will help out the next person who wants to use moment in a simple fnction node
Much appreciated.
Craig
