Monitor battery value
Gents,
I have many zigbee sensors running on batteries. I want to read the value of the batteries of some sensors and if it is less than 30 percent I want to turn on a virtual device i have on my ihost.
the following data i am getting from my sensor.
how can i do that in nodered. I am still on learning curve.
thank you
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
If that doesn't help you to get access to the battery value then I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
