Giamma
14 September 2021 12:30
1
in relation to this post:
Hi there
does anybody have a small and simple moon phase + picture script / export for my personal dashboard ?
i was looking but could not find any
many many thanks in advance
Menno
I set node sun position lo show in my dashboard moon position icon ..
Well ...
I have two dashboard, on one I see this icon
but on the other I see this icon
Why?
I don't understand, I'd like to see the first icon for both ...
They are two very different things so it is not possible that you have same exact flow to produce this. Investigate or let us see, by sharing the flow(s)
Colin
14 September 2021 14:53
3
Giamma:
Is that on different systems or both in the same instance of node-red?
Giamma
14 September 2021 15:09
4
This is the flow ....
If I set the node Moon img into a dashboard I have the first icon, if I set the same node into the other dashboard I have the second icon.
It's the same flow, only change the dashboard ....
Giamma
14 September 2021 16:01
5
Ok,
I found the problem, but not the solution .....
This is the dashboard show on browser Chromium directly from Raspberry ...
and this is the same dashboard show on pc ubuntu connect on raspberry (of course), but the browser is Firefox ...... (on pc)
Giamma
14 September 2021 16:06
6
And with Opera or Chrome this is the same dashboard ..... (on pc)
It's really blurry ....
Giamma
14 September 2021 16:17
7
Well,
it's possible that Raspberry don't have these icons?
jbudd
14 September 2021 16:23
8
If you don't like the way different browsers are displaying the (Unicode?) emoji, you could display your own image instead.
Giamma
14 September 2021 16:41
9
I installed Firefox on Raspberry, but I have not the correct Icon (only black and white),
so the problem is Raspberry or the icons are missing?
jbudd
15 September 2021 08:47
12
Well done. That's much nicer!
