Slightly following up from this thread:
That is/was a problem.
At the time I was using FF as my browser.
It is the latest - AFAIK. 70.1 or something.
NR is 1.0.3
Anyway, I am working on a project and decided: rather than load FF (with it's numerous tabs - see Last post by me
I would load/use Chromium. I have it also installed.
Loaded and set off working with NR and the project.
Note: at this point FF is NOT loaded. Chrome has maybe 5 tabs open.
Mostly local NR dashboards.
I had to start again with the sub flow as there is a problem importing them.
Anyway, things were going well, and I was trying things.
Then the gremlins came knocking.
This machine's specs:
NUC
Intel® Core™ i5-7260U CPU @ 2.20GHz × 4
64 bit
16 Gig of ram
So, I was doing things and the results weren't as expected/usual.
Something is wrong!
I open the sub flow window and the input is not connected. I check and none of the outputs were either.
something removed the connections.
And it wasn't me.
I re-connected them and things became better.
Still not prefect, but that's because I haven't completed the project.
What is going on?
Any ideas?
Could it be something to do with the no response from server error/s?
(Which is the same machine)
