What is wrong with Aedes broker?
Well what seems to be wrong with it?
What version of node-red are you running?
What platform?
You will have to check the full Node-RED log to see the details of the error the aedes node is logging.
it's not usable
I have just found that all brokers are not working with me also
windows, 2.2.2
how can I access it?
It depends how you are running Node-RED. If you can share some details, we'll be able to help
I just installed Aedes via Manage Palette.
I added the Aedes node once to any flow, double click on it & accept the defaults and it works. But I'm running Node-red on Linux. Not much help, sorry.
[{"id":"3ec835604e58db01","type":"inject","z":"3e125034173a4229","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"test","payload":"Hello","payloadType":"str","x":240,"y":120,"wires":[["a764dd69fc50e24e"]]},{"id":"42970ffb393ea353","type":"mqtt in","z":"3e125034173a4229","name":"","topic":"test","qos":"2","datatype":"auto","broker":"86f554b2e0381a0b","nl":false,"rap":true,"rh":0,"inputs":0,"x":210,"y":180,"wires":[["a540bbf501bc360d"]]},{"id":"a764dd69fc50e24e","type":"mqtt out","z":"3e125034173a4229","name":"","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"86f554b2e0381a0b","x":430,"y":120,"wires":[]},{"id":"a540bbf501bc360d","type":"debug","z":"3e125034173a4229","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":450,"y":180,"wires":[]},{"id":"d60c830a10b66ea9","type":"aedes broker","z":"3e125034173a4229","name":"","mqtt_port":1883,"mqtt_ws_bind":"port","mqtt_ws_port":"","mqtt_ws_path":"","cert":"","key":"","certname":"","keyname":"","dburl":"","usetls":false,"credentials":{},"x":250,"y":60,"wires":[[],[]]},{"id":"86f554b2e0381a0b","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Aedes node works for me on Windows
it's okay with me on raspberry but not on my laptop
I'm using windows 10, nodered V2.2.2
