I want to try this basic ESP8266 MQTT example :
I want to publish a msg on Node-red
I started mosquitto .
But I'm getting this error ,:
Anyone have an idea where is the problem please?
not really node-red related - but you need to check the mosquitto logs on the box where you are running your mqtt broker for any entries
You might want to give a bit more detail as to your setup as well in terms of what is running Node-red mosquitto etc etc
Craig
I edited the post, I want to get the msg on node-red
OK so as i said
Craig
For node-red to communicate it uses MQTT - you are trying to communicate from the ESP8266 to Node-red - the middle man is MQTT.
The MQTT software is setup to be a Broker.
Typically MQTT is provided on Linux by a program called Mosquitto (there are others) - i have no idea what kali linux provides - you do realise Kali is a security focused distribution for doing things like penetration testing and the like - it is not designed to be a daily drive (unless it has evolved way past what i saw last time i used it ?)
What box are you running Kali on and why are you running it rather than something mainstream ?
Craig
Are you running this on a PC or a Raspberry PI ?
If a PC i prefer Centos but the majorirty of people use Ubuntu
You will need to find the Mosquitto log location on Kali - try /var/log/mosquitto as a good starting point.
Then you can tail the file and watch it to see if your ESP is talking to it correctly
Thank you I will try it,
But I didn't my ESP didn't connect to the mqtt server yet
Your code says your MQTT broker is at 127.0.0.1 - that is the local loopback address of any device. This means the device thinks it is the MQTT broker.
You need to set that to the actual IP address of the machine that is the MQTT broker.
The one I got with the command : hostname -I ??
No, that just returns the local loop back address. try this
ifconfig wlan0
and you will get something like this:
pi@yellowpi:~ $ ifconfig wlan0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.48.115 netmask 255.255.255.0 broadcast 192.168.48.255
inet6 fe80::4f3d:9a6e:9bd4:bbe8 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:40:54:1b txqueuelen 1000 (Ethernet)
RX packets 296708 bytes 76022934 (72.5 MiB)
RX errors 0 dropped 408 overruns 0 frame 0
TX packets 148026 bytes 35057664 (33.4 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
On the second lin see the inet? In my case my mqtt broker is running on 192.168.48.115 so that is the adddress you need to enter in the code for the ESP8266
const char* mqtt_server = "192.168.48.115"; but use your address not mine
I tried it and it works perfectly haha Thanks
