MQTT connection failed to broker, and ESP-01
I am having an issue with Node-red and the MQTT broker. I'll let you know, I am very new to Node-red, and my coding is amateur at best. I did not create the flow I am using, or the code. I do fine working with code, just not creating it.
Node-red works fine, except I get the repeating line "Connection failed to broker". I'm connecting my project through an ESP8266-01 to a wifi network, and to my Win 10 PC. I know I am probably missing something simple, but not sure where to look. Here is the NR log, and ESP code below. Let me know if you need any more info. Thanks!
3 Mar 10:02:22 - [info] Node-RED version: v2.0.5
3 Mar 10:02:22 - [info] Node.js version: v14.16.0
3 Mar 10:02:22 - [info] Windows_NT 10.0.19044 x64 LE
3 Mar 10:02:23 - [info] Loading palette nodes
3 Mar 10:02:24 - [info] Dashboard version 2.30.0 started at /ui
3 Mar 10:02:24 - [info] Settings file : C:\Users\mrdog.node-red\settings.js
3 Mar 10:02:24 - [info] Context store : 'default' [module=memory]
3 Mar 10:02:24 - [info] User directory : \Users\mrdog.node-red
3 Mar 10:02:24 - [warn] Projects disabled : editorTheme.projects.enabled=false
3 Mar 10:02:24 - [warn] Flows file name not set. Generating name using hostname.
3 Mar 10:02:24 - [info] Flows file : \Users\mrdog.node-red\flows_DRAGON2.json
3 Mar 10:02:24 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
3 Mar 10:02:24 - [info] Starting flows
3 Mar 10:02:24 - [info] Started flows
3 Mar 10:02:24 - [info] [mqtt-broker:288a79fc1071de7a] Connection failed to broker: mqtt://localhost :1883
And here is the code for the ESP in case it makes a difference. I only included the wifi and MQTT code for simplicity. I did set SSID and PW for my home network. The httpPort was just a test.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include "Arduino.h"
const char* ssid = "SSID";
const char* password = "Password";
const IPAddress mqttServerIP(192,168,254,14);
// const int httpPort = 1883;
const char* deviceID = "ESP8266";
WiFiClient wifiClient;
PubSubClient MQTTClient(wifiClient);
long lastMsgTime = 0;
char msg[64];
char topic[32];
int pulseCount = 0;
Have you installed an MQTT broker? If so then what broker have you installed, which computer have you installed it on, and which computer is node-red running on?
Thanks for the quick response. No, I hadn't installed a broker, and feeling a bit ashamed I didn't realize it was an external thing from Node-red. So I installed Mosquitto and I'll work on figuring out how to set the configuration. All of this will be running on the same PC. Is there a simple tutorial for Mosquitto?
Quick edit, Node-red and Mosquitto are running, the broker connected, and I have a connection showing on my flow. OMG can't believe I missed that. Thank you!!!!!!
It should just go if you accessing via localhost. You have to tweak it for access from a different machine, not at my pc so haven't got the details here. Has been addressed a few times here.
To learn all about MQTT then see this tutorial MQTT Essentials - All Core Concepts explained
At my computer now. You have to add the mosquitto conf file
listener 1883
allow_anonymous true
That allows access to the broker without credentials from other machines on the network.
Where the conf file is depends on the OS and it looks as if you aren't using a Debian Linux so can't help there.
