I am a beginner and I cant get it to work. I use Home assistant and Node-Red latest version.
I got two inject with Topic "light/garage_out" and Paylod "On" / "Off" connected to one MQTT-out, Server: HA-1@192.168.1.87:1883 no username or password.
One MQTT-in connected to a debug.
Connected is Ok but it dont work.
Logg:
[13:31:00] INFO: Setup mosquitto configuration
[13:31:00] INFO: No local user available
[13:31:00] INFO: Initialize Hass.io Add-on services
[13:31:00] INFO: Initialize Home Assistant discovery
[13:31:00] INFO: Start Mosquitto daemon
1581597060: mosquitto version 1.6.3 starting
1581597060: Config loaded from /etc/mosquitto.conf.
1581597060: Loading plugin: /usr/share/mosquitto/auth-plug.so
1581597060: |-- *** auth-plug: startup
1581597060: ├── Username/password checking enabled.
1581597060: ├── TLS-PSK checking enabled.
1581597060: └── Extended authentication not enabled.
1581597060: Opening ipv4 listen socket on port 1883.
1581597060: Opening ipv6 listen socket on port 1883.
1581597060: Opening websockets listen socket on port 1884.
1581597060: Opening ipv4 listen socket on port 8883.
1581597060: Opening ipv6 listen socket on port 8883.
1581597060: Opening websockets listen socket on port 8884.
1581597060: Warning: Mosquitto should not be run as root/administrator.
1581597061: New connection from 192.168.1.87 on port 1883.
1581597062: Socket error on client , disconnecting.
1581597062: New connection from 192.168.1.87 on port 1883.
1581597062: New client connected from 192.168.1.87 as auto-D9004764-F203-5A2F-0EF7-8B33FFC2C788 (p2, c1, k60).
1581597072: New connection from 192.168.1.87 on port 1883.
1581597072: New client connected from 192.168.1.87 as HA-1 (p2, c0, k120).
What can I do?
