I have an issue with my MQTT setup.
It would appear that all msg.payloads in are being received twice and I cannot figure out why? Also, if I choose a different server it will change the server to the same on all other MQTT nodes. Any help would be welcomed.
2nd one first... When you are editing the broker ... I suspect you are just editing the broker you already have defined - rather than adding a second one. If your existing nodes are set to use the "first" one - editing it will edit it for all of them.
Ah, interesting. I seem to have developed a bad habit of copying nodes and editing rather than starting new. Thank-you for this. I will see if this has anything to do with my initial problem as well.
