Hello
My device takes the value in the JSON format like {Flow:65} where Flow is the Tag name and 65 is the set value when i use inject to MQTT out its working fine but i want to send this by using slider and MQTT out .
Please guide how to use it i tried to insert function in between to add value from slider like
D={Flow:{value}}
return D;
but its not working as output is coming value is not defined
Welcome to the forum.
It isn't at all clear where you are putting that code. Is that in a function node? If so, you need to go back and look again how data is passed into a function node and how it is passed out again.
I am using a slider to pass data to function node. And i want the output of function node to be in this format {"Flow":value} where value should come from slider.
maybe try
msg.payload = { Flow : msg.payload };
return msg
Thanks for your support , its working now.
