Hi.
This is how you do it with the two nodes.
Please understand I can't set the MQTT topic, etc.
But this is how you connect them.
[{"id":"821e7123.2c3898","type":"ui_slider","z":"9245b569.9f881","name":"","label":"slider","tooltip":"","group":"596129cc.2bc108","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"","min":0,"max":10,"step":1,"x":460,"y":4610,"wires":[["a323ab00.fdf3c"]]},{"id":"a323ab00.fdf3c","type":"mqtt out","z":"9245b569.9f881","name":"","topic":"","qos":"","retain":"","x":610,"y":4610,"wires":[]},{"id":"596129cc.2bc108","type":"ui_group","z":"","name":"Load monitor","tab":"6bedb3c5.f5ae94","order":2,"disp":true,"width":"3"},{"id":"6bedb3c5.f5ae94","type":"ui_tab","z":"","name":"TimePi Remote control","icon":"fa-dashboard","order":1,"disabled":false,"hidden":false}]
Copy all this to your clipboard.
Go into Node-red and import via the menu on the right.
Paste the code into the box/area for input.
One suggestion - which I set - is to set the slider node so it only sends the value once you release the slider.
Good luck and welcome to node-red.
This is what it looks like:
