These two tags were defined in my eth-ip node and I can see their values in debug. How can I pass these values using msg.payload?
It would be easier if you showed the dubg so we can be sure of the property names.
So in a chnage node.
set msg. payload
to value of msg. TimerTag.PRE
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path and value to any data item.
Thank you for your suggestion!
I did not need to use the change node.
Its needed syntax is msg.payload["TimerTag.ACC"]
"id": "92f84c2279a8c4b9",
"type": "eth-ip in",
"z": "d92a57752d6bc843",
"endpoint": "dfecf1530cd22ce7",
"mode": "all",
"variable": "",
"program": "",
"name": "L30ER_PLC",
"x": 139,
"y": 57,
"3c14b97a237b36d0"
"id": "31572d115a93c089",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "TimerTag.PRE",
"tot": "msg"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "TimerTag.ACC",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 440,
"y": 40,
"id": "e793a7de09997f80",
"type": "debug",
"name": "debug 6",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 360,
"y": 200,
"id": "3c14b97a237b36d0",
"type": "function",
"name": "node status",
"func": "node.status({fill:\"green\", shape:\"dot\", text:\"Value: \"+msg.payload[\"TimerTag.ACC\"]});\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 470,
"y": 120,
"id": "dfecf1530cd22ce7",
"type": "eth-ip endpoint",
"address": "10.10.10.11",
"slot": "0",
"cycletime": "500",
"name": "L30ER",
"vartable": {
"TimerTag.ACC": {
"type": "DINT"
"TimerTag.PRE": {
"type": "DINT"
Noted that if you are using 'st-ethernet-ip' module, the payload tag is really straight forward.
msg.payload. TimerTag.PRE
