Not getting tag value from node-red-contrib-cip-st-ethernet-ip node in debug
I am trying to read tag rom Rockwell 1769-L33ER/A compact Logix plc by using node-red-contrib-cip-st-ethernet-ip node version 2.0.3 . ETH ip in node configure with cycle = 2000 ms and timeout is 40000 ms.
        "id": "c42847500a2b5440",
        "type": "tab",
        "label": "Building",
        "disabled": false,
        "info": "",
        "env": []
        "id": "35534078f120a7ac",
        "type": "eth-ip in",
        "z": "c42847500a2b5440",
        "endpoint": "36adb93f8834e3f7",
        "mode": "all-split",
        "variable": "RUNNING_RECIPE_NAME",
        "program": "",
        "name": "F-1",
        "gatherMetrics": false,
        "includeTimestamp": false,
        "addErrorOutput": false,
        "outputs": 1,
        "x": 170,
        "y": 200,
                "b13ad5620d467917"
        "id": "b13ad5620d467917",
        "type": "debug",
        "name": "debug 11",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 600,
        "y": 200,
        "id": "36adb93f8834e3f7",
        "type": "eth-ip endpoint",
        "address": "172.16.20.101",
        "slot": "0",
        "cycletime": "2000",
        "timeout": "10000",
        "name": "F-1",
        "connectedMess": false,
        "vartable": {
                "RUNNING_RECIPE_NAME": {
                    "type": "REAL",
                    "mapping": "Size"
                "TBM_NUMBER": {
                    "type": "REAL",
                    "mapping": "McName"
                "BUILDER_NAME": {
                    "type": "STRING",
                    "mapping": "Operator"
                "RecipeCom_Description.Carcass_Code": {
                    "type": "STRING",
                    "mapping": "GTcode"
                "GT_Count": {
                    "type": "DINT",
                    "mapping": "Prod"
I am not able to see value in debug node as per cycle when I am doing debug only 1 time value come. Value not coming in debug every 2 second.
Any Help in this regard appreciated.
