I am trying to read tag rom Rockwell 1769-L33ER/A compact Logix plc by using node-red-contrib-cip-st-ethernet-ip node version 2.0.3 . ETH ip in node configure with cycle = 2000 ms and timeout is 40000 ms. OS WIN 10 node JS 24.0.
"id": "c42847500a2b5440",
"type": "tab",
"label": "Building",
"disabled": false,
"info": "",
"env": []
"id": "35534078f120a7ac",
"type": "eth-ip in",
"z": "c42847500a2b5440",
"endpoint": "36adb93f8834e3f7",
"mode": "all-split",
"variable": "RUNNING_RECIPE_NAME",
"program": "",
"name": "F-1",
"gatherMetrics": false,
"includeTimestamp": false,
"addErrorOutput": false,
"outputs": 1,
"x": 170,
"y": 200,
"b13ad5620d467917"
"id": "b13ad5620d467917",
"type": "debug",
"name": "debug 11",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 600,
"y": 200,
"id": "36adb93f8834e3f7",
"type": "eth-ip endpoint",
"address": "172.16.20.101",
"slot": "0",
"cycletime": "2000",
"timeout": "10000",
"name": "F-1",
"connectedMess": false,
"vartable": {
"RUNNING_RECIPE_NAME": {
"type": "REAL",
"mapping": "Size"
"TBM_NUMBER": {
"type": "REAL",
"mapping": "McName"
"BUILDER_NAME": {
"type": "STRING",
"mapping": "Operator"
"RecipeCom_Description.Carcass_Code": {
"type": "STRING",
"mapping": "GTcode"
"GT_Count": {
"type": "DINT",
"mapping": "Prod"
I am not able to see value in debug node as per cycle when I am doing debug only 1 time value come. Value not coming in debug every 2 second.
i have also tried with different os and different node also but no luck.
