Please check the below images.
Same payload array passed to TVP parameter
Change node rules are,
So, as I said, the format is incorrect.
Your UDT_Rolemanagement parameter is set to get data from msg.payload - a TVP MUST be formatted as I have pointed out.
Change the UDT parameter value to payload.table;
BETWEEN the switch node and MSSQL, add a function node with this code inside...
//convert the payload array of objects to a flat array
var rows = msg.payload.map(e => [e.functionid, e.Accessid]);
//get the id and name from the payload.
var id = msg.payload.id;
var name = msg.payload.name;
//setup the table and its columns
var table = {};
table.columns = [
"name": "functionid",
"type": "int"
"name": "Accessid",
"type": "int"
//add the rows to the table
table.rows = rows;
//create a NEW payload with .id, .name and .table properties
msg.payload = {
table: table
//return the updated message to the next node
table:
columns: [
{ name: 'functionid', type: 'int' },
{ name: 'Accessid', type: 'int' },
rows: [ [2,1], [3,1] ]
