Node-red-contrib-mssql-plus Execute Procedure
Hi all!
Could anyone give my an example of executing a stored procedure (with 2 parameters), please?
gives me msg.payload: undefined
This is the working SQL studio code:
USE [xxx]
GO
DECLARE	@return_value int
EXEC	@return_value = [dbo].[Store_Procedure]
		@type = 14,
		@year = 23
SELECT	'Return Value' = @return_value
GO
I don't use this node but you can try this one, you configure your query directly in the payload as an object.
What is the "query mode" drop-down set to?
