I have only 2 or 3 functions defined in my settings.js file (so I can use them anywhere) and I sure do seem to use them. Since time math is always working with milliseconds (wait, duration, periods) I found that constantly converting them to hh:mm:ss for the Dashboard or log file became a pain.
I saw on a forum somewhere a small snippet of code called msToTime (author was not identified). That triggered the idea for me to create such a function in my settings.js.file, (under functionGlobalContext: ) so I thought I'd share it.
Once installed there, to call it and use it is as follows:
USE: context.global.msToTime( number, [boolean1], [boolean2] )
number = time (ms) booloean1 (optional) = true || false || null (show ms || no ms || no ms) NOTE: if no ms, seconds are rounded down ( 00:00:15:852 = 00:00:15 ) booloean2 (optional) = true || false (JSON out || string out)EXAMPLES:
context.global.msToTime(1644591214165) = "52 years, 54 days, 14:53:34"
context.global.msToTime(354165) = "00:05:54"
context.global.msToTime(354165, true) = "00:05:54:165"
context.global.msToTime(1644591214165, true) = "52 years, 54 days, 14:53:34:165"
context.global.msToTime(1644591214165, null, true) =
{"years":52,"days":54,"hours":14,"minutes":53,"seconds":34,"milliseconds":165}
If you need just hours and minutes only (assuming input # has no years or days) use substr(0, 5):
var time = {payload: context.global.msToTime(12345678) };
// result: "03:25:45"
var time = {payload: context.global.msToTime(12345678).substr(0,5) };
// result: "03:25"
Here is the function:
// , <--- settings.js: comma is needed if another custom function before this.
msToTime: function msToTime(duration, ms, json)
if (typeof (duration) != 'number') return "NaN";
if (duration < 0) return "Err < 0";
var milliseconds = Math.round(duration % 1000),
seconds = Math.floor((duration / 1000) % 60),
minutes = Math.floor((duration / (1000 * 60)) % 60),
hours = Math.floor((duration / (1000 * 60 * 60)) % 24),
days = Math.floor((duration / (1000 * 60 * 60 * 24)) % 365),
years = Math.floor((duration / (1000 * 60 * 60 * 24 * 365)) % 365),
result, json_result;
years = (years > 0) ? years : 0;
days = (days > 0) ? days : 0;
hours = (hours < 10) ? ("00" + hours).slice(-2) : hours;
minutes = (minutes < 10) ? ("00" + minutes).slice(-2) : minutes;
seconds = (seconds < 10) ? ("00" + seconds).slice(-2) : seconds;
milliseconds = ("00" + milliseconds).slice(-3);
json_result = [{"years": years, "days": days, "hours": Number(hours), "minutes": Number(minutes), "seconds": Number(seconds), "milliseconds": Number(milliseconds) }];
years = (years > 0) ? years + " years, " : "";
days = (days > 0) ? days + " days, " : "";
if (ms) result = years + days + hours + ":" + minutes + ":" + seconds + ":" + milliseconds
else result = years + days + hours + ":" + minutes + ":" + seconds;
if (json) return json_result
else return result;
// , <--- settings.js: comma is needed if another custom function after this.
