Multi MQTT and function
Hi I just started learning NodeRED
I have some question about Multi MQTT input to function
I have 5 MQTT subscribe topic
  1. value (update every 5 sec)
  2. stage (retained messages)
  3. auto (retained messages)
  4. max (retained messages)
  5. min (retained messages)
my function
var relay_stage = String(msg.relay_stage);
var auto_mode = String(msg.auto_mode);
var soil_val = Number(msg.soil_val);
var soil_max = Number(msg.soil_max);
var soil_min = Number(msg.soil_min);
if (auto_mode == "on"){
    if (soil_val >= soil_max && relay_stage == "on"){
        msg.payload = "off";
    else if (soil_val <= soil_min && relay_stage == "off"){
        msg.payload = "on";
but it's not work please help
You will need to join the messages using a join node, then feed them into the function, as messages arrive at different times.
Read this page to see an example of joining messages.
https://cookbook.nodered.org/basic/join-streams
Now I have Object like
name/sensor/soil1/value : msg.payload : Object
{ name/sensor/soil1/min: "23", name/power/relay1/auto: "on", name/power/relay1/stage: "off", name/sensor/soil1/max: "54", name/sensor/soil1/value: "0.0" }
Can you guide some example function code for use this Object?
Sorry for noob question I'm really new here
Thank you
Post your flow and i will edit it to give topics better names.
when posting use bacticks around code, make sure backticks are on new line on their own.
eg
code
Thank you
[{"id":"882513f.6bf8af","type":"mqtt in","z":"8b1bcb5e.22a118","name":"","topic":"name/sensor/soil1/value","qos":"2","datatype":"auto","broker":"","x":410,"y":300,"wires":[["350850d1.a621"]]},{"id":"1f28993a.435c87","type":"mqtt in","z":"8b1bcb5e.22a118","name":"","topic":"name/sensor/soil1/min","qos":"2","datatype":"auto","broker":"","x":400,"y":420,"wires":[["350850d1.a621"]]},{"id":"52075a8c.092b54","type":"mqtt in","z":"8b1bcb5e.22a118","name":"","topic":"name/power/relay1/auto","qos":"2","datatype":"auto","broker":"","x":410,"y":240,"wires":[["350850d1.a621"]]},{"id":"60f23533.0a8bcc","type":"mqtt in","z":"8b1bcb5e.22a118","name":"","topic":"name/power/relay1/stage","qos":"2","datatype":"auto","broker":"","x":410,"y":180,"wires":[["350850d1.a621"]]},{"id":"3d97dff0.d1077","type":"mqtt in","z":"8b1bcb5e.22a118","name":"","topic":"name/sensor/soil1/max","qos":"2","datatype":"auto","broker":"","x":400,"y":360,"wires":[["350850d1.a621"]]},{"id":"350850d1.a621","type":"join","z":"8b1bcb5e.22a118","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"5","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":670,"y":300,"wires":[["7e7f42ee.4313cc"]]},{"id":"7e7f42ee.4313cc","type":"debug","z":"8b1bcb5e.22a118","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":830,"y":300,"wires":[]}]
Do what you did before but the path to the variables have changed.
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
Try this, I have split the topic and used the last value to create the payload, then in your function i have referenced these payload propeties
eg.
[{"id":"729cda57.87488c","type":"change","z":"5a245aa1.510164","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"$split(topic, \"/\")[-1]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":3940,"wires":[["350850d1.a621"]]},{"id":"882513f.6bf8af","type":"mqtt in","z":"5a245aa1.510164","name":"","topic":"name/sensor/soil1/value","qos":"2","datatype":"auto","broker":"","x":130,"y":3940,"wires":[["729cda57.87488c"]]},{"id":"1f28993a.435c87","type":"mqtt in","z":"5a245aa1.510164","name":"","topic":"name/sensor/soil1/min","qos":"2","datatype":"auto","broker":"","x":120,"y":4060,"wires":[["729cda57.87488c"]]},{"id":"60f23533.0a8bcc","type":"mqtt in","z":"5a245aa1.510164","name":"","topic":"name/power/relay1/stage","qos":"2","datatype":"auto","broker":"","x":130,"y":3820,"wires":[["729cda57.87488c"]]},{"id":"3d97dff0.d1077","type":"mqtt in","z":"5a245aa1.510164","name":"","topic":"name/sensor/soil1/max","qos":"2","datatype":"auto","broker":"","x":120,"y":4000,"wires":[["729cda57.87488c"]]},{"id":"52075a8c.092b54","type":"mqtt in","z":"5a245aa1.510164","name":"","topic":"name/power/relay1/auto","qos":"2","datatype":"auto","broker":"","x":130,"y":3880,"wires":[["729cda57.87488c"]]},{"id":"350850d1.a621","type":"join","z":"5a245aa1.510164","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":610,"y":3940,"wires":[["15cf54a0.38e2e3","7e7f42ee.4313cc"]]},{"id":"15cf54a0.38e2e3","type":"function","z":"5a245aa1.510164","name":"","func":"var relay_stage = String(msg.payload.stage);\nvar auto_mode = String(msg.payload.auto);\nvar soil_val = Number(msg.payload.value);\nvar soil_max = Number(msg.payload.max);\nvar soil_min = Number(msg.payload.min);\n\nif (auto_mode == \"on\"){\n    if (soil_val >= soil_max && relay_stage == \"on\"){\n        msg.payload = \"off\";\n        return msg;\n    }\n    else if (soil_val <= soil_min && relay_stage == \"off\"){\n        msg.payload = \"on\";\n        return msg;\n    }\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":770,"y":3940,"wires":[["7e7f42ee.4313cc"]]},{"id":"7e7f42ee.4313cc","type":"debug","z":"5a245aa1.510164","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":4100,"wires":[]}]
woww its worked perfectly,
Thank you, you saved my day
