I face one problem . I want to set up a multi user dashboard with a switch node
unfortunately i don't find the way to set up the switch node in multi user
the switch node is affected for all users.
Is there someone who already set up such configuration ?
is there a flow to share to help me to understand the use of switch node in Mdashboard
THanks for help
mdashboard was a fork of dashboard that had some subtle changes in this area so you would need to contact the developer of that (if they still maintain it).
In dashboard the switch is indeed common to all - intentionally - so that everyone knows the state of the switch at that time. (EG it would be dangerous if I turn off the power to something - then you turn it back on and I didn't know...)
