Multiple Output Issue
I'm trying to join messages on the first trigger I only get one output, and the second I get 4
How to I Modify the flow so that I only get 1 output all the time?
and for the record, just starting out with Node-Red :slight_smile:
Thanks for any assistance
Here is current Flow
[{"id":"437eba92.ecec0c","type":"tab","label":"Flow 8","disabled":false,"info":""},{"id":"c400a9c4.73f2","type":"mqtt in","z":"437eba92.ecec0c","name":"Shelly-DW2-State","topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/state","qos":"0","datatype":"auto","broker":"d8008000.6ed7d","x":210,"y":180,"wires":[["21ac7796.29f1e"]]},{"id":"b8b3f864.171bc","type":"mqtt in","z":"437eba92.ecec0c","name":"Shelly-DW2-LUX","topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/lux","qos":"0","datatype":"auto","broker":"d8008000.6ed7d","x":200,"y":240,"wires":[["9cefa657.dc5788"]]},{"id":"d3497056.5407d8","type":"mqtt in","z":"437eba92.ecec0c","name":"Shelly-DW2-Battery","topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/battery","qos":"0","datatype":"auto","broker":"d8008000.6ed7d","x":210,"y":360,"wires":[["63291b89.744b64"]]},{"id":"b4c810c.ee090f","type":"mqtt in","z":"437eba92.ecec0c","name":"Shelly-DW2-Temp","topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/temperature","qos":"0","datatype":"auto","broker":"d8008000.6ed7d","x":210,"y":300,"wires":[["2e0a609c.9e5538"]]},{"id":"21ac7796.29f1e","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"state","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":180,"wires":[["1deb281.e73afd8"]]},{"id":"9cefa657.dc5788","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"lux","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":240,"wires":[["1deb281.e73afd8"]]},{"id":"2e0a609c.9e5538","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"temp","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":300,"wires":[["1deb281.e73afd8"]]},{"id":"63291b89.744b64","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"battery","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":360,"wires":[["1deb281.e73afd8"]]},{"id":"1deb281.e73afd8","type":"join","z":"437eba92.ecec0c","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":630,"y":280,"wires":[["da68a8e7.243088","ef8dd9ba.ff997","186e58d6.b28fc7"]]},{"id":"da68a8e7.243088","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"DoorStatus","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":360,"wires":[[]]},{"id":"186e58d6.b28fc7","type":"debug","z":"437eba92.ecec0c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1010,"y":200,"wires":[]},{"id":"ef8dd9ba.ff997","type":"debug","z":"437eba92.ecec0c","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":160,"wires":[]},{"id":"d8008000.6ed7d","type":"mqtt-broker","name":"","broker":"192.168.1.176","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Every thing is working as it should. the first time through the join node needs 4 inputs before it will pass on joined message, after that it will add any new message to existing and then pass on. if you wish it to wait for another 4, just uncheck "every subsequent message".
you can also use wildcards and split topic , check my example
[{"id":"c400a9c4.73f2","type":"mqtt in","z":"437eba92.ecec0c","name":"Shelly-DW2-State","topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/#","qos":"0","datatype":"auto","broker":"d8008000.6ed7d","x":210,"y":180,"wires":[["21ac7796.29f1e"]]},{"id":"21ac7796.29f1e","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"$split(topic,\"/\")[-1]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":180,"wires":[["1deb281.e73afd8"]]},{"id":"1deb281.e73afd8","type":"join","z":"437eba92.ecec0c","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":570,"y":180,"wires":[["da68a8e7.243088","ef8dd9ba.ff997","186e58d6.b28fc7"]]},{"id":"654dbc8d.5dcccc","type":"inject","z":"437eba92.ecec0c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/state","payload":"open","payloadType":"str","x":210,"y":240,"wires":[["21ac7796.29f1e"]]},{"id":"f7078b29.590f88","type":"inject","z":"437eba92.ecec0c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/lux","payload":"250","payloadType":"str","x":210,"y":280,"wires":[["21ac7796.29f1e"]]},{"id":"4f5ef5ac.1aadfc","type":"inject","z":"437eba92.ecec0c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/temp","payload":"25","payloadType":"str","x":210,"y":320,"wires":[["21ac7796.29f1e"]]},{"id":"b145e05d.a489a","type":"inject","z":"437eba92.ecec0c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"shellies/shellydw2-XXXXXXXXXXX/sensor/battery","payload":"89","payloadType":"str","x":210,"y":360,"wires":[["21ac7796.29f1e"]]},{"id":"da68a8e7.243088","type":"change","z":"437eba92.ecec0c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"DoorStatus","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":240,"wires":[[]]},{"id":"ef8dd9ba.ff997","type":"debug","z":"437eba92.ecec0c","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":160,"wires":[]},{"id":"186e58d6.b28fc7","type":"debug","z":"437eba92.ecec0c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1010,"y":200,"wires":[]},{"id":"d8008000.6ed7d","type":"mqtt-broker","name":"","broker":"192.168.1.176","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
i added injects just for testing
Thanks, E1cid
That worked like a charm
Always comes down to one check mark lol
