Multiple text input in notification
Hi all,
I'm building something like a login dialogue.
To do this I'm using the node notification but I don't find a way to have more than one text input.
There is a way to have more than one text input?
This is my flow from now but it did not send the value of the first text input.
I think because the first one is in the title.
[{"id":"273f2657952486e5","type":"ui_toast","z":"a95c4d40.a6cc6","position":"prompt","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":true,"className":"","topic":"","name":"","x":530,"y":700,"wires":[["d915d2a3baa50d61"]]},{"id":"94e23136411f9681","type":"function","z":"a95c4d40.a6cc6","name":"function 2","func":"msg.payload = `<md-input-container md-no-float=\"\" ng-if=\"::dialog.$type == 'prompt'\" class=\"md-prompt-input-container md-auto-horizontal-margin md-input-has-placeholder md-default-theme md-input-has-value\" style=\"\"><input ng-keypress=\"dialog.keypress($event)\" md-autofocus=\"\" ng-model=\"dialog.result\" placeholder=\"\" ng-required=\"dialog.required\" class=\"ng-valid md-autofocus md-input ng-valid-required ng-not-empty ng-dirty ng-valid-parse ng-touched\" id=\"input_138\" aria-invalid=\"false\" style=\"\"><div class=\"md-errors-spacer\"></div></md-input-container>`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":700,"wires":[["273f2657952486e5","362f8bfd332a9ea1"]]},{"id":"7aa4980e48c5f343","type":"inject","z":"a95c4d40.a6cc6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":700,"wires":[["94e23136411f9681","783c117fc538ed24"]]},{"id":"d915d2a3baa50d61","type":"debug","z":"a95c4d40.a6cc6","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":740,"y":700,"wires":[]},{"id":"362f8bfd332a9ea1","type":"debug","z":"a95c4d40.a6cc6","name":"debug 2","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":540,"y":740,"wires":[]},{"id":"783c117fc538ed24","type":"debug","z":"a95c4d40.a6cc6","name":"debug 3","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":360,"y":740,"wires":[]}]
Do you have any suggestions?
Admin Edit, I have edited the flow above to add newline before backticks on the end of the flow, to allow it to be imported.
Perhaps you could build up something with the ui-template-node. I found an interesting solution for a modal alert dialog which possibly could be converted to one with input fields:
        "id": "06ce0c67de868d70",
        "type": "tab",
        "label": "Flow 5",
        "disabled": false,
        "info": "",
        "env": []
        "id": "29554d9cf6288f39",
        "type": "ui_template",
        "z": "06ce0c67de868d70",
        "group": "52e13bbe911008c8",
        "order": 0,
        "width": 0,
        "height": 0,
        "format": "<script>\n(function(scope){\nvar testShowAlert = function ($mdDialog) {\nvar alert = $mdDialog.alert({\ntitle: 'Attention',\ntextContent: 'This is an example of how simple dialogs can be!',\nok: 'Close'\n});\n\n  $mdDialog\n    .show( alert )\n    .finally(function() {\n      alert = undefined;\n    });\n}\n\nscope.showAlert = function() {\n       var injector = angular.element(\"#nr-dashboard\").injector();\n       injector.invoke(testShowAlert,null,null);\n};\n\n})(scope);\n</script>\n<button ng-click=\"showAlert()\">Test Alert</button>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 1000,
        "y": 220,
        "id": "52e13bbe911008c8",
        "type": "ui_group",
        "name": "TestGroup",
        "tab": "322aeab29d79e631",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "322aeab29d79e631",
        "type": "ui_tab",
        "name": "Alert",
        "icon": "dashboard",
        "order": 4,
        "disabled": false,
        "hidden": false
It's from this forum discussion:
https://discourse.nodered.org/t/how-to-show-modal-dialog-in-template-node/611
And the used service is documented here:
https://material.angularjs.org/latest/api/service/$mdDialog#javascript-object-syntax
I didn't go any further!
