Mustache template with node-red-contrib-graphql
I used a change node to set msg.payload.inventory_item_id to 42112828440781
Next I use the graphql node (from node-red-contrib-graphql) to run the following GraphQL query:
  inventoryItem(id: "gid://shopify/InventoryItem/{{inventory_item_id}}") {
    variant {
      sku
      title
      product {
        id
        title
I set the node to use moustache templating. However, the {{inventory_item_id}} is being replaced with nothing. This results in the following error: "Invalid global id 'gid://shopify/InventoryItem/'"
The docs for node-red-contrib-graphql state:
If you select mustache, your template will be processed by Mustache with the message's payload as an argument. I.e.
submitted_template = mustache("template in text area", msg.payload)
Am I missing something?
Aha! I had to reference it as {{payload.inventory_item_id}}
Did I misunderstand the docs or are they wrong?
I have not used that particular contrib node, but if I recall correctly, the context of the core template node is the full msg object, not just the playload...
Have you tried this?
"gid://shopify/InventoryItem/{{payload.inventory_item_id}}"
If that does work, then I guess the documentation just needs to be updated.
If not, then I have no idea ;*)
Jinx! nice catch
