Mute node on debug screen
Hello all,
I am using the OPCUA Node to subscribe to multiple nodeIds and upon a good read, it will output: CytroPac: StatusCode: Good (0x00000000)
Usually this would be ok with the debug filter however, it is also clogging up the terminal which I use to monitor my database input.
Is there a way for me to mute that node so that it would not send out debugs?
Hi. You may need to raise this as an issue directly on that node’s GitHub page.
