My Flows are gone
After not being able to deploy my new Flow, all of my flows were gone. I still have the Backup data of my flows. What should i do now? Had anyone the same problem yet?
What happened? why were you not able to deploy. What did you see on screen?
Can you go to your .node-red directory and run ls -la, then post either a screenshot or copy/paste the results.
Also if you stop node-RED, then restart it and copy the node-RED log here also.
When posting logs, flows or code in the forum, please read this first about how to do so, otherwise the forum software will change your upload.
Dear Paul,
Thank you for your answer i already fixed it:).
I was working on a project, editing my function node after that i was not able to deploy… already had that problem once so i wanted to delete the whole flow where the problem was taking part —> all of the flows were gone (because i made a mistake deleting the wrong file) so i got kinda nervous and wasnt able to import my backup (saved before deleting) because i was very nervous and not able to think clear… but now its working again. Long Story short…it was my mistake and i was kinda „dumb“
We've all been there :laughing:
