I made a deploy and after that 2 flows dissapeared . The strange fact is that they seem to work perfectly in UI . Except that the Deploy button is no longer working . i am running node-red with pm2 but i dont know what that means . I attach what i see when i start node red .Please advise . An extra clue is that before the catastrophic deploying the vm NR is running on, had 97% RAM usage after the disappearence of the the flows i mentioned that RAM usage went down to 65 % but as i said the disappeared flows are still working.
0|node-red | 18 Apr 02:39:30 - [info] Node-RED version: v1.0.3
0|node-red | 18 Apr 02:39:30 - [info] Node.js version: v12.15.0
0|node-red | 18 Apr 02:39:30 - [info] Linux 4.4.0-176-generic x64 LE
0|node-red | 18 Apr 02:39:30 - [info] Loading palette nodes
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-bigtimer 2.3.1
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-bigtimer
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-boolean-logic 0.0.3
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-boolean-logic
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-boolean-logic-ultimate 1.0.12
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-boolean-logic-ultimate
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-facebook-messenger-writer 0.0.5
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-facebook-messenger-writer
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-home-assistant 0.3.2
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-home-assistant
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-interval 0.0.1
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-interval
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-loop-processing 0.4.0
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-loop-processing
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-modbus 5.2.0
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-modbus
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-os 0.1.7
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-os
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-s7 2.1.1
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-s7
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-scheduler 1.0.5
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-scheduler
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-simple-gate 0.3.0
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-simple-gate
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-slack 2.0.0
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-slack
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-slack-files 0.1.2
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-slack-files
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-slackbot 1.0.3
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-slackbot
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-stoptimer 0.0.7
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-stoptimer
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-time-range-switch 1.0.0
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-time-range-switch
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-traffic 0.2.1
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-traffic
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-contrib-ui-level 0.1.23
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-contrib-ui-level
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-dashboard 2.19.3
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-dashboard
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-email 1.7.4
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-email
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-feedparser 0.1.15
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-feedparser
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-random 0.1.4
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-random
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-rbe 0.2.8
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-rbe
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-sqlite 0.4.2
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-sqlite
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-twilio 0.1.0
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-twilio
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-twitter 0.1.15
0|node-red | 18 Apr 02:39:31 - [debug] /home/nodered/.node-red/node_modules/node-red-node-twitter
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-rbe 0.2.6 ignored due to local copy
0|node-red | 18 Apr 02:39:31 - [debug] /usr/lib/node_modules/node-red/node_modules/node-red-node-rbe
0|node-red | 18 Apr 02:39:31 - [debug] Module: node-red-node-tail 0.0.3
0|node-red | 18 Apr 02:39:31 - [debug] /usr/lib/node_modules/node-red/node_modules/node-red-node-tail
0|node-red | 18 Apr 02:39:34 - [info] Dashboard version 2.19.3 started at /ui
0|node-red | 18 Apr 02:39:34 - [info] Settings file : /home/nodered/.node-red/settings.js
0|node-red | 18 Apr 02:39:34 - [info] Context store : 'default' [module=memory]
0|node-red | 18 Apr 02:39:34 - [info] User directory : /home/nodered/.node-red
0|node-red | 18 Apr 02:39:34 - [warn] Projects disabled : editorTheme.projects.enabled=false
0|node-red | 18 Apr 02:39:34 - [info] Flows file : /home/nodered/.node-red/flows_nodered.json
0|node-red | 18 Apr 02:39:34 - [info] Server now running at http://127.0.0.1:1880/
0|node-red | 18 Apr 02:39:34 - [debug] loaded flow revision: 1c0aa439b6717facf9c54f98ce631740
0|node-red | 18 Apr 02:39:34 - [debug] red/runtime/nodes/credentials.load : no user key present
0|node-red | 18 Apr 02:39:34 - [debug] red/runtime/nodes/credentials.load : using default key
0|node-red | 18 Apr 02:39:34 - [debug] red/runtime/nodes/credentials.load : keyType=system
. It is strange groups in the mqtt test are visible for me . Anyway i think i have screw it up . I may have to build from scratch
