Why are you asking the serial node to break data up into lengths of 8 bytes when your specification states 13 byte values will be returned for a 252 request?
Something is a miss.
I suspect you need to send a character AFTER 252 (like a CR or LF or ETX)
Do you have a link to the documentation?
Many thanks for all the help so far.
Documentation is very limited. What I send you above is all I have. The uart serial port is very basic an uses al the basic/standard setup and protocols I was told.
I think you are correct the data from the serial port is incorrect.
The reason I split it I was trying to split it from the serial port. That was before I was aware of the buffer parser node.
Buffer parser tries to simplify a quite complex problem of turning a buffer of bytes into usable INTS, FLOATS, STRINGS etc.
The incoming buffer can be chopped and packaged up in a nice payload object (ideal for when you want all values in one place) OR multiple payloads with a topic (ideal for MQTT) OR multiple payloads from multiple outputs (ideal for routing messages)
Example...
Its in the help info, but here is a simple example...
Many thanks I really appreciate all your help.
I am always right sometimes ![]()
It looks daunting but thats due to the task of number extraction and conversion and the billions of combinations possible. I like to think it simplifies things for users (once they get past the initial "what is all this" stage)
You're most welcome.
I managed to get it all working
