Need help about Securing Node-RED on Docker
Hi, I just installed node-red on docker and need to use username and password to login before go to node-red page
install
sudo docker run -d --restart=always -p 1880:1880 -v node_red_data:/data --name node-red nodered/node-red
create password
sudo docker exec -it node-red npx node-red admin hash-pw
edit <setting.js> file
vi node_modules/node-red/settings.js
adminAuth: { type: "credentials", users: [{ username: "admin", password: "xxxxxxxxxx" permissions: "*" }] }
restart node-red
sudo docker restart node-red
that what I did I still can go to node-red no login need did I miss songthing??
Thank you :slight_smile:
the settings.js file is located in your node_red_data volume.
thank you
