Need help and I'm an absolute beginner
I will create an Flow, where the Friends of hue Switch (there are 4 Buttons) send an 1 to garden door if I press the button.
I don't know which node I have to use for that and I have no idea how I get an "1" to the "Gartentor" output.... so long I press the Button 1.
In the picutre attached you see, what I get on the Debug Note, when I press the Button 1.
I would be really a pleasure, if someone helps me... I have no Idea.....
Thanks a lot
Hi @logol01, welcome.
first you need to use the switch node to route your message according to the action, then using a change node you can set the payload to what ever you require.
If you use a debug node and use the copy value button that appears when you hover near the object name, you can then post a copy of the incoming objects. I could then use that to post an example flow for you.
You should take some time and read through the node-red docs and watch the videos, as this will help you understand many things, including how to share info and how message routing work and how to share flows, import/export.
When sharing code on this forum it is best to use the </> button in the post editor
I found an other solution....
This works perfect for my Problem.
I used a fuction node with the following code:
const Button = msg.payload.button;
const Action = msg.payload.action;
if(Button === 1 && Action === 'initial_press'){
return {payload: 1}
if(Button === 1 && Action === 'short_release'){
return {payload: 0}
