Need help displaying data each interval
Im having trouble to display data every 5 seconds interval after using the switch node. But when i debug the node before it reaches the switch node, the output shows what its supposed to every 5 seconds. Hope you guys can help me with this. Below is my flow;
[{"id":"b4f66c67.11694","type":"inject","z":"33298230.b1694e","name":"","topic":"","payload":"StringData","payloadType":"global","repeat":"5","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":120,"wires":[["b5a2f96d.2d98b8"]]},{"id":"4a8bb6e5.0628e8","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":60,"wires":[]},{"id":"fee2783.6487988","type":"inject","z":"33298230.b1694e","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":180,"wires":[["b772f531.8eeb48"]]},{"id":"b772f531.8eeb48","type":"function","z":"33298230.b1694e","name":"","func":"global.set(\"StringData\",\"1 2 3 4 5 \");\nreturn msg;","outputs":1,"noerr":0,"x":340,"y":180,"wires":[[]]},{"id":"b5a2f96d.2d98b8","type":"split","z":"33298230.b1694e","name":"","splt":" ","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":true,"addname":"","x":410,"y":120,"wires":[["4a8bb6e5.0628e8","a2538e41.8e82c"]]},{"id":"a2538e41.8e82c","type":"change","z":"33298230.b1694e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":140,"wires":[["7600ed7b.9c0a34"]]},{"id":"7600ed7b.9c0a34","type":"switch","z":"33298230.b1694e","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":720,"y":240,"wires":[["e0ae2ad8.7654b8"],["420444a4.20cf0c"],["cda710de.4cb8b"],["9901502d.ab861"],["f9288d5b.24a72"]]},{"id":"e0ae2ad8.7654b8","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":880,"y":180,"wires":[]},{"id":"420444a4.20cf0c","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":880,"y":220,"wires":[]},{"id":"cda710de.4cb8b","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":260,"wires":[]},{"id":"9901502d.ab861","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":300,"wires":[]},{"id":"f9288d5b.24a72","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":340,"wires":[]}]
what datatype are you sending to the switch and what datatype are you testing?
p.s. you have a second bug you will need to fix, but I think you shold be able to find it.
I was sending the number 1-5 with the split function everytime it founds a space. The data shows perfectly in each interval of 5 secs before i add in the switch node so it displays the data in different outputs. I think this flow works better.
[{"id":"4a8bb6e5.0628e8","type":"debug","z":"33298230.b1694e","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":60,"wires":[]},{"id":"fee2783.6487988","type":"inject","z":"33298230.b1694e","name":"","topic":"","payload":"","payloadType":"date","repeat":"5","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":120,"wires":[["b772f531.8eeb48"]]},{"id":"b772f531.8eeb48","type":"function","z":"33298230.b1694e","name":"","func":"var newMsg = {payload: \"1 2 3 4 5 \"}\nreturn newMsg;","outputs":1,"noerr":0,"x":260,"y":120,"wires":[["b5a2f96d.2d98b8"]]},{"id":"b5a2f96d.2d98b8","type":"split","z":"33298230.b1694e","name":"","splt":" ","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":true,"addname":"","x":410,"y":120,"wires":[["4a8bb6e5.0628e8","a2538e41.8e82c"]]},{"id":"a2538e41.8e82c","type":"change","z":"33298230.b1694e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":140,"wires":[["7600ed7b.9c0a34"]]},{"id":"7600ed7b.9c0a34","type":"switch","z":"33298230.b1694e","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":720,"y":240,"wires":[["e0ae2ad8.7654b8"],["420444a4.20cf0c"],["cda710de.4cb8b"],["9901502d.ab861"],["f9288d5b.24a72"]]},{"id":"e0ae2ad8.7654b8","type":"debug","z":"33298230.b1694e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":180,"wires":[]},{"id":"420444a4.20cf0c","type":"debug","z":"33298230.b1694e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":220,"wires":[]},{"id":"cda710de.4cb8b","type":"debug","z":"33298230.b1694e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":260,"wires":[]},{"id":"9901502d.ab861","type":"debug","z":"33298230.b1694e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":300,"wires":[]},{"id":"f9288d5b.24a72","type":"debug","z":"33298230.b1694e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":890,"y":340,"wires":[]}]
try changing your debug nodes to display the 'Complete msg object' and see it that gives you more to debug with
Also I would shut off the internal so you can manually inject to see what happens each time and I'd try just using 2 numbers instead of 5
Have an especially close look at the msg.parts.index property you are testing for. You can even change the debug node just to show you this property:
[{"id":"23c12be8.0d7cec","type":"inject","z":"f954564f.03e718","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":460,"y":2860,"wires":[["f4ac441f.17e598"]]},{"id":"f4ac441f.17e598","type":"function","z":"f954564f.03e718","name":"","func":"var newMsg = {payload: \"1 2 3 4 5 \"}\nreturn newMsg;","outputs":1,"noerr":0,"x":620,"y":2860,"wires":[["637ce2c3.245a94"]]},{"id":"637ce2c3.245a94","type":"split","z":"f954564f.03e718","name":"","splt":" ","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":true,"addname":"","x":770,"y":2860,"wires":[["175d4e78.8b9622"]]},{"id":"175d4e78.8b9622","type":"change","z":"f954564f.03e718","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":2860,"wires":[["87c8edb5.d49b7","b60ec983.343638"]]},{"id":"87c8edb5.d49b7","type":"switch","z":"f954564f.03e718","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":1070,"y":2960,"wires":[["cae54f4d.8cb5"],["e5c86628.8c1eb8"],["39db57a6.213458"],["e97ceb4d.bf9ab8"],["6af8fa7d.b9908c"]]},{"id":"cae54f4d.8cb5","type":"debug","z":"f954564f.03e718","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":2920,"wires":[]},{"id":"e5c86628.8c1eb8","type":"debug","z":"f954564f.03e718","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":2960,"wires":[]},{"id":"39db57a6.213458","type":"debug","z":"f954564f.03e718","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":3000,"wires":[]},{"id":"e97ceb4d.bf9ab8","type":"debug","z":"f954564f.03e718","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":3040,"wires":[]},{"id":"6af8fa7d.b9908c","type":"debug","z":"f954564f.03e718","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1250,"y":3080,"wires":[]},{"id":"b60ec983.343638","type":"debug","z":"f954564f.03e718","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"parts.index","targetType":"msg","x":1140,"y":2820,"wires":[]}]
I modified your flow so that you can manually inject and will see just this property in the debug.
Best regards Johannes
