Need help on SVG
Dear all I have this VERY simple flow, but It didn't work.
I don't know what wrong with this, I just want to change the text and color of an Element in SVG, but I can't do it.
[{"id":"102121b4.89e68e","type":"ui_svg_graphics","z":"a01466e1.d8c328","group":"b1a0a83c.d02578","order":0,"width":0,"height":0,"svgString":"<svg xmlns=\"http://www.w3.org/2000/svg\" xmlns:svg=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" x=\"0\" y=\"0\" height=\"100\" viewBox=\"0 0 100 100\" width=\"100\">\n  <rect id=\"svgEditorBackground\" x=\"0\" y=\"0\" width=\"100\" height=\"100\" style=\"fill:none; stroke: none;\"/><text style=\"\" x=\"23.252033233642578\" y=\"18.536584854125977\" id=\"e1_text\" fill=\"black\" font-family=\"Arial\" font-size=\"20px\">Hello</text></svg>","clickableShapes":[],"smilAnimations":[],"bindings":[{"selector":"#e1_text","bindSource":"payload.label","bindType":"text","attribute":""},{"selector":"#e1_text","bindSource":"payload.color","bindType":"attr","attribute":"fill"}],"showCoordinates":false,"autoFormatAfterEdit":false,"outputField":"payload","editorUrl":"http://drawsvg.org/drawsvg.html","directory":"","name":"","x":620,"y":200,"wires":[[]]},{"id":"fcee325d.3f59e","type":"inject","z":"a01466e1.d8c328","name":"","topic":"","payload":"{\"label\":\"this is a test!\",\"color\":\"White\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":290,"y":180,"wires":[["102121b4.89e68e"]]},{"id":"b1a0a83c.d02578","type":"ui_group","z":"","name":"Group 1","tab":"fbefeb56.059148","order":1,"disp":true,"width":"30","collapse":false},{"id":"fbefeb56.059148","type":"ui_tab","z":"","name":"SVG","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
THanks in Advance !
Are you certain payload is an object and had the required property set to match up with the binding?
Attach a debug node before the and after the SVG node (ensure debug nodes have show complete msg option set)
Attach screen shots of the debug output here.
Hello Steve, Thanks for response.
I actually forgot that in order to do binding, the message should have a topic of 'databind', I feel so noob about that 🤦
Hi @Henjoe,
Thanks for your feedback, because it helps us to understand which kind of difficulties our users have!
I have added a new tutorial "Use databinding to simplify the input message structure" to the SVG node's wiki page, to avoid that other users would run into the same issue as you.
Bart
Thanks Bart ! :slight_smile:
I do really appreciate this amazing node.
