Need help reproducing DB2 animation
I'm trying to recreate the Dashboard 2.0 ui-gauge-tank with a custom unit (i need somthing else than %). I used the Vue component i found on Dashboard 2.0's github, and adapted it to change the unit. It works well but I can't get the wave animation working correctly...
I'm using node-red v4.0.9, NodeJS v22.14.0 and Dashboard 2.0 V1.22.1
Here's my flow :
        "id": "7c0a6281fad8692c",
        "type": "tab",
        "label": "Flux 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "c26cf52ff92bf8dc",
        "type": "inject",
        "z": "7c0a6281fad8692c",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "15",
        "payloadType": "num",
        "x": 170,
        "y": 200,
                "77736be83ff7aa82"
        "id": "77736be83ff7aa82",
        "type": "function",
        "name": "function 2",
        "func": "msg.min = 4\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 380,
        "y": 200,
                "442aaa386a504831"
        "id": "f2bc295826c5e605",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "15",
        "x": 150,
        "y": 260,
                "d0ccf216830a748d"
        "id": "442aaa386a504831",
        "type": "ui-template",
        "group": "fb6501fa7d8b6b7b",
        "page": "",
        "ui": "",
        "name": "custom-tank",
        "order": 1,
        "width": "3",
        "height": "3",
        "head": "",
        "format": "<template>\n  <div v-resize=\"onResize\" class=\"nrdb-ui-gauge-tank--container\">\n    <label class=\"nrdb-ui-gauge-title\"> CUSTOM-TANK</label>\n\n    <div\n        class=\"nrdb-ui-gauge-tank\"\n        :style=\"{'--gauge-fill': color, '--gauge-fill-pc': pc + '%', 'color': color}\"\n    >\n      <div class=\"nrdb-ui-gauge-tank--center\">\n        <div ref=\"fill\" class=\"nrdb-ui-gauge-tank--fill\"></div>\n        <svg class=\"WaveBG\" :style=\"`bottom: 0; height: ${svgBottom}px`\" :viewBox=\"`0 ${amplitude_setting} 1000 ${Math.min(100, svgScaleRatio * svgBottom)}`\" preserveAspectRatio=\"xMinYMin meet\">\n          <path :d=\"waves[0]\">\n            <animate\n                dur=\"5s\"\n                repeatCount=\"indefinite\"\n                attributeName=\"d\"\n                :values=\"`${waves[0]}; ${waves[1]}; ${waves[0]};`\"\n            />\n          </path>\n        </svg>\n        <svg class=\"Wave\" :style=\"`bottom: 0; height: ${svgBottom}px;`\" :viewBox=\"`0 ${amplitude_setting} 1000 ${Math.min(100, svgScaleRatio * svgBottom)}`\" preserveAspectRatio=\"xMinYMin meet\">\n          <path :d=\"waves[0]\">\n            <animate\n                dur=\"5s\"\n                repeatCount=\"indefinite\"\n                attributeName=\"d\"\n                :values=\"`${waves[0]}; ${waves[1]}; ${waves[0]};`\"\n            />\n          </path>\n        </svg>\n\n      <div ref=\"labels\" class=\"nrdb-ui-gauge-tank-labels\">\n        <label class=\"nrdb-ui-gauge-tank--label\" >{{ this.value }} T</label>\n      </div>\n    </div>\n    </div>\n\n  </div>\n</template>\n<script>\nexport default {\n\n  data() {\n    return {\n      labelLineHeight: 0,\n      svgBottom: 0,\n      amplitude_setting: 15,\n      svgScaleRatio: 1,\n      minivalue : 0,\n      maxivalue : 50\n    }\n  },\n  watch: {\n    value: function () {\n      this.$nextTick(() => {\n        // react to the fill element being updated\n        this.updateMask()\n      })\n    }\n  },\n  computed: {\n\n    color: function ()\n    {\n      if (this.value <= this.min) {return \"#FF0000\"}\n      return \"#00FF00\"\n    }\n    ,\n    pc: function () {\n      if (typeof this.value !== 'undefined') {\n        return Math.max(0, Math.min(Math.round((this.value - this.minivalue) / (this.maxivalue - this.minivalue) * 100), 100))\n      } else {\n\n        return 0\n      }\n    },\n    clipId: function () {\n      return `clip-${this.id}`\n    },\n    waves: function () {\n      const amplitude = this.amplitude_setting * this.svgScaleRatio\n      const svgBottom = this.svgBottom\n      const svgScaleRatio = this.svgScaleRatio\n\n      return [\n        `M750,${amplitude} c -125,0 -125,-${amplitude} -250,-${amplitude} s -125,${amplitude} -250,${amplitude} S 125,0, 0,0 v${svgScaleRatio * (svgBottom + amplitude)}h1000 V0 c-125,0 -125,${amplitude} -250,${amplitude}Z`,\n        `M750,0 c -125,0 -125,${amplitude} -250,${amplitude} S 375,0 250,0, S 125,${amplitude}, 0,${amplitude} v${svgScaleRatio * svgBottom}h1000 V${amplitude} c-125,0 -125-${amplitude} -250-${amplitude}Z`\n      ]\n    }\n  },\n  methods: {\n    updateMask () {\n      const h = this.$refs.fill?.clientHeight || 0\n      const w = this.$refs.fill?.clientWidth || 0\n\n      this.labelLineHeight =`${this.$refs.labels.clientHeight}px`\n\n      if (h >= 0 && this.pc !== 0) {\n        this.svgBottom = h\n        this.svgScaleRatio = w !== 0 ? 1000 / w : 1\n      } else {\n        this.svgBottom = 0\n        this.svgScaleRatio = 1\n      }\n    },\n    onResize () {\n      this.updateMask()\n    }\n  },\n  mounted () {\n\n    this.$nextTick(() => {\n      this.updateMask()\n    })\n\n    this.$socket.on('msg-input:' + this.id, (msg) => {\n      this.value = msg.payload\n      this.min = msg.min\n    })\n  },\n  unmounted() {\n\n  }\n}\n\n</script>\n<style scoped>\n.Wave,\n.WaveBG {\n  width: 200%;\n  position: absolute;\n  overflow: visible;\n  animation-name: swell;\n  animation-fill-mode: forwards;\n  animation-iteration-count: infinite;\n  animation-timing-function: linear;\n  fill: var(--gauge-fill);\n  bottom: var(--gauge-fill-pc);\n}\n\n.WaveBG {\n  opacity: 0.4;\n  /* offset the animation so that the wave's standing nodes never overlap */\n  animation-duration: 1.5s;\n  animation-delay: 1.2s;\n}\n.Wave {\n  animation-duration: 2s;\n}\n\n@keyframes swell {\n  0% {\n    transform: scaleX(2) translateX(25%) translateY(1px);\n  }\n  100% {\n    transform: scaleX(2) translateX(-25%) translateY(1px);\n  }\n}\n\n.nrdb-ui-gauge-tank--container {\n  display: flex;\n  flex-direction: column;\n  container: tank-container / size;\n}\n.nrdb-ui-gauge-tank {\n  --tank-margin: 6px;\n  --tank-padding: 3px;\n  --tank-radius: 6px;\n  --tank-border: 4px;\n}\n\n@container tank-container (min-width: 75px) and (min-height: 75px) {\n  .nrdb-ui-gauge-tank {\n    --tank-margin: 12px;\n    --tank-radius: 12px;\n    --tank-border: 8px;\n    --tank-padding: 6px;\n  }\n}\n\n.nrdb-ui-gauge-tank {\n  border-radius: var(--tank-radius);\n  border-width: var(--tank-border);\n  padding: var(--tank-padding);\n  border-color: var(--gauge-fill);\n  border-style: solid;\n  flex-grow: 1;\n  position: relative;\n}\n.nrdb-ui-gauge-tank--fill {\n  background-color: transparent;\n}\n.nrdb-ui-gauge-tank-labels {\n  position: relative;\n  width: 100%;\n  height: 100%;\n  display: flex;\n  container-type: size;\n}\n.nrdb-ui-gauge-tank label {\n  font-weight: bold;\n  display:flex;\n  resize: both;\n  font-size: min(2.5rem, 50cqmin);\n  position: absolute;\n  z-index: 2;\n  width: 100%;\n  height: 100%;\n  text-align: center;\n  justify-content: center;\n  align-items: center;\n  color: black;\n  --text-border: 1px;\n  --text-border-inv: calc(-1 * 1px);\n  --text-border-color: white;\n  text-shadow: var(--text-border) var(--text-border-inv) var(--text-border-color),\n  var(--text-border-inv) var(--text-border-inv) var(--text-border-color),\n  var(--text-border-inv) var(--text-border) var(--text-border-color),\n  var(--text-border) var(--text-border) var(--text-border-color);\n}\n\nnrdb-ui-gauge-title {\n  font-weight: bold;\n  display:flex;\n  resize: both;\n  font-size: min(2.5rem, 50cqmin);\n  position: absolute;\n  z-index: 2;\n  width: 100%;\n  height: 100%;\n  text-align: center;\n  justify-content: center;\n  align-items: center;\n  color: black;\n\n}\n\n.nrdb-ui-gauge-tank--center {\n  display: flex;\n  justify-content: center;\n  align-items: center;\n  height: 100%;\n  position: relative;\n  overflow: hidden;\n}\n\n/* text mask */\n.nrdb-ui-gauge-tank svg.mask {\n  top: 0;\n}\n.nrdb-ui-gauge-tank svg.mask,\n.nrdb-ui-gauge-tank--fill {\n  position: absolute;\n  left: 0;\n}\n.nrdb-ui-gauge-tank--fill {\n  bottom: 0;\n  height: var(--gauge-fill-pc);\n  width: 100%;\n}\n</style>",
        "storeOutMessages": true,
        "passthru": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 610,
        "y": 200,
        "id": "c6cc4137fbb3cdda",
        "group": "",
        "page": "d30cf1a71bcee0b6",
        "ui": "",
        "name": "Dasboard 2.0 CSS",
        "order": 0,
        "width": 0,
        "height": 0,
        "head": "",
        "format": ".nrdb-ui-text {\n    background-color: #eeeeee !important;\n}\n\n.nrdb-ui-gauge {\n        background-color: #eeeeee !important;\n}\n\n.nrdb-ui-gauge-title {\n        font-size: larger;\n        background-color: aqua;\n}\n\n.valid.valid-label label {\n    color: black;\n}\n\n.valid.dark-text span {\n    color: black;\n}\n\n.valid.valid-text span {\n    color: green;\n}\n\n.invalid.invalid-label label {\n    color: black;\n}\n\n.invalid.invalid-text span {\n    color: red;\n}\n\n",
        "passthru": false,
        "templateScope": "page:style",
        "className": "",
        "x": 190,
        "y": 100,
        "id": "d0ccf216830a748d",
        "type": "ui-gauge",
        "name": "tank",
        "order": 2,
        "width": "3",
        "height": "3",
        "gtype": "gauge-tank",
        "gstyle": "needle",
        "title": "TANK",
        "units": "Bar",
        "icon": "",
        "prefix": "",
        "suffix": "",
        "segments": [
                "from": "0",
                "color": "#ff0000"
                "from": "4",
                "color": "#00ff40"
        "min": 0,
        "max": "50",
        "sizeThickness": 16,
        "sizeGap": 4,
        "sizeKeyThickness": 8,
        "styleRounded": true,
        "styleGlow": false,
        "className": "custom-tank",
        "x": 590,
        "y": 260,
        "id": "fb6501fa7d8b6b7b",
        "type": "ui-group",
        "name": "Group Name",
        "page": "fd51264148764b4f",
        "width": "12",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "fd51264148764b4f",
        "type": "ui-page",
        "name": "Page Name",
        "ui": "955d24bee66399fa",
        "path": "/exemple",
        "icon": "home",
        "layout": "grid",
        "theme": "4cbed8b158df0175",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "955d24bee66399fa",
        "type": "ui-base",
        "name": "UI Name",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "page",
        "navigationStyle": "default",
        "titleBarStyle": "default",
        "showReconnectNotification": true,
        "notificationDisplayTime": "1",
        "showDisconnectNotification": true
        "id": "4cbed8b158df0175",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094CE",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "density": "default",
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
Thanks in advance for your help!
