Need help with node-red-contrib-mongodb4
I use node-red-contrib-mongodb4 and I use find operation.
I want to sort and limit output.
Please show me how to use sort or limit.
Thanks.
Hello .. i did some tests with Mongodb but i used node-red-node-mongodb node instead of mongodb4
.. i think their syntax should be more or less the same
Try to set the operation to an aggregate query
and below is an example where i search between two dates and sort by descending order
let startDate = msg.payload.startDate || "2020-01-10 00:00:00";
let endDate = msg.payload.endDate || "2021-01-15 07:00:00";
msg.collection = "temperatures"
msg.operation = "aggregate"
msg.payload = [
//{$unwind: "$temps"},
{ "$match": { "dt": { "$gte": startDate, "$lte": endDate }}},
{ "$sort": { dt: -1}},
//{"$limit": 2},
//{"$skip": 0}
