Node-red-contrib-mongodb4
Moving to node-red-contrib-mongodb4 and I'm having issues.
I can perform a find operation, but I cannot for the life of me pass in any options like $sort or $limit
From a function node, I setup the collection and operations:
msg.collection = "foo";
msg.operation = "find";
I try two types of methods in attempt to implementing the options:
method #1:
 const options = {
     $sort : { "_id" : -1   },
     $limit : 1
msg.payload = [
    msg.searchQuery,
    options
and this function node passes the msg to a node-red-contrib-mongodb4 node,
which performs the find, but returns all documents.
I've also tried to do so by method of it's processor : node-red-contrib-mongodb (which worked well)
by tacking on the msg object:
method #2:
msg.payload = msg.searchQuery
msg.sort = { "_id" : -1}
msg.limit = 1
Still neither of these methods work for me and are still returning the full set of documents, and not limiting the return.
I just can't seem to get these find options to work.
Not sure what I'm doing wrong here.
I was able to do this with an aggregate operation, but the caveat was it needed double brackets??
msg.collection = global.get("db")["submissions"];
msg.operation = "aggregate"
msg.payload =  // Pipeline
        // Stage 1
            $match: {
                // conditional query
                "season_code": "CODE2021"
        // Stage 2
        {$limit : 1}
This code example produced a working result when passed to the node.
