hi how find in mongodb data base
exp I need find this UUID : "a506e376-b38b-473d-a7aa-a70652cdacb5"
or this id: next and equal :
how it
I use this msg but not work
msg.find = {"UUID":{ $in:"a506e376-b38b-473d-a7aa-a70652cdacb5"}};
but return all document
Which mongo node are you using?
Does its sidebar help say to put the query in msg.find? Off the top of my head, I'm not aware of a node that uses msg.find (but I haven't tried them all). Most nodes would expect the query to be in msg.topic or msg.payload.
msg.projection = {"UUID":{ $in:"a506e376-b38b-473d-a7aa-a70652cdacb5"}, "ack":1};
error return
"MongoError: Unsupported projection option: UUID: { $in: "a506e376-b38b-473d-a7aa-a70652cdacb5" }"
That node expects the find options to be in msg.payload.
so I use this
msg.payload = {_id: {$gt: ObjectId("5ea4995f4a677c4e68acb899" )}}
now error return:
"ReferenceError: ObjectId is not defined (line 4, col 27)"
when used this
msg.payload = {UUID: {$in:"a506e376-b38b-473d-a7aa-a70652cdacb5" }}
return error
"MongoError: $in needs an array"
if used without $in
msg.payload = {"UUID":"a506e376-b38b-473d-a7aa-a70652cdacb5"}
"_msgid":"42d8881b.1fdbc8",
"topic":"",
"payload":[
"_id":"5ea4995f4a677c4e68acb89a",
"topic":"ps30kv/RTU",
"payload":"[{\"topic\":\"ACK-RTU\",\"payload\":\"switch dp\"}]",
"qos":0,
"retain":false,
"_msgid":"e45548ec.cfe208",
"time":"Sat Apr 25 2020 21:11:11 GMT+0100 (GMT+01:00)",
"ack":true,
