Need help with why I can't install a node. node-red-node-watson
Node of interest:
I have it installed on my NUC and it works.
But this is my day to day machine and not one of my always on machines.
I'm wanting to use/install it on there but can't.
I accept/appreciate that it is > 1 year out of date.
But if I go to the library and look for that node it is listed and shows the speech nodes listed.
The machine onto which I want to install it is a RasPi V3b running Buster.
Just wanting to ask if it can/should work on that machine.
Thanks in advance.
If I try to update it I get this:
I just installed it on a Pi running bullseye and it seems to have gone OK
I sometimes find removing a node and re-installing it is the quickest way of sorting some things out
Interesting.
This is what I did:
pi@TimePi:~ $ cd .node-red
pi@TimePi:~/.node-red $ node-red-restart
Restarted Node-RED
pi@TimePi:~/.node-red $ npm install node-red-node-watson
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
> es5-ext@0.10.62 postinstall /home/pi/.node-red/node_modules/es5-ext
>  node -e "try{require('./_postinstall')}catch(e){}" || exit 0
npm WARN node-red-contrib-ui-led@0.4.8 requires a peer of node-red-dashboard@^2.23.3 but none is installed. You must install peer dependencies yourself.
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
+ node-red-node-watson@0.10.3
updated 18 packages, moved 2 packages and audited 408 packages in 79.72s
23 packages are looking for funding
  run `npm fund` for details
found 18 vulnerabilities (1 low, 11 moderate, 6 high)
  run `npm audit fix` to fix them, or `npm audit` for details
Restarted Node-RED
If I go to the GUI, this is what I see.
SORRY!
Sod's law stepped in and now it seems to be ok.
