hello, I'm new here.
I would like to insert a text input into my dashboard, where I can enter an IP address, for example. If this is confirmed, a new visualization page should be created automatically. Is this possible? I have a page for an engine with right, left and other data. Now I want to expand this to 500 more engines and a user should be able to add new engines via the dashboard in the future.
Thank you for your help.
Have you tried it? If so, have you run into an issue? If not, why not try and see what you can create? The best way to learnis by trying out different things. Make liberal use of the debug node (make sure to name them) to see what is happening at different points of the flow.
