Hi everybody,
I'm in this forum for more than a month getting information and solving my problems, but now I stuck with a string problem.
I'm using version 1.2.6 of node red in a raspberry Pi 3B+.
I found a flow for my APC UPS, and I'm getting the data from the apcupsd, but the info comes in a big string of info, and I can't get what I need.
This is the string:
APC : 001,043,1001DATE : 2021-01-27 09:52:47 -0100 HOSTNAME : DreamVERSION : 3.14.14 (31 May 2016) debianUPSNAME : APCCABLE : USB CableDRIVER : USB UPS DriverUPSMODE : Stand AloneSTARTTIME: 2021-01-24 11:42:55 -0100 MODEL : Smart-UPS 1000 STATUS : ONLINE LINEV : 244.8 VoltsLOADPCT : 0.0 PercentBCHARGE : 100.0 PercentTIMELEFT : 291.0 MinutesMBATTCHG : 5 PercentMINTIMEL : 3 MinutesMAXTIME : 0 SecondsOUTPUTV : 244.8 VoltsSENSE : HighDWAKE : -1 SecondsDSHUTD : 180 SecondsLOTRANS : 208.0 VoltsHITRANS : 253.0 VoltsRETPCT : 0.0 PercentITEMP : 28.3 CALARMDEL : 30 SecondsBATTV : 27.5 VoltsLINEFREQ : 50.0 HzLASTXFER : No transfers since turnonNUMXFERS : 0TONBATT : 0 SecondsCUMONBATT: 0 SecondsXOFFBATT : N/ASELFTEST : NOSTESTI : 14 daysSTATFLAG : 0x05000008MANDATE : 2004-10-18SERIALNO : AS0443230286BATTDATE : 2004-10-18NOMOUTV : 220 VoltsNOMBATTV : 24.0 VoltsFIRMWARE : 600.3.I USB FW:1.5END APC : 202...
The flow that I'm using is this one (not mine), but adapted to me:
[{"id":"ff997979.d294b8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"73db5098.7513c","type":"exec","z":"ff997979.d294b8","command":"/sbin/apcaccess","addpay":false,"append":"","useSpawn":"","timer":"","name":"apcaccess","x":350,"y":140,"wires":[["dca40517.33c468","b4aed1aa.aec878"],[],[]]},{"id":"a3de16ec.d1803","type":"inject","z":"ff997979.d294b8","name":"every 10 seconds","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"str","x":177,"y":139,"wires":[["73db5098.7513c"]]},{"id":"dca40517.33c468","type":"function","z":"ff997979.d294b8","name":"Parse apcaccess data","func":"var wanted = ['upsname', 'serialno', 'status', 'linev', 'linefreq', 'loadpct', 'battv', 'bcharge', 'timeleft', 'itemp', 'xonbatt', 'xoffbatt'];\nvar lines = msg.payload.trim().split(\"\\n\");\nvar outputMsgs = [];\nvar mqtttopic = 'home/common/ups/APC';\n\n// loop over every line\nlines.forEach(function (line) {\n // assign values\n var stats = line.split(' : ');\n var label = stats[0].toLowerCase();\n var value = stats[1];\n\n // remove surrounding spaces\n label = label.replace(/(^\\s+|\\s+$)/g, '');\n context.curValues = context.curValues || {};\n context.curValues[label] = context.curValues[label] || 0;\n\n // if found as wanted value, store it\n if (wanted.indexOf(label) > -1) {\n value = value.replace(/(^\\s+|\\s+$)/g, '');\n if (context.curValues[label] != value) {\n outputMsgs.push({topic:mqtttopic + '/' + label, payload:value});\n context.curValues[label] = value;\n }\n }\n});\n\nreturn [ outputMsgs ];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":120,"wires":[["be0d6ac0.c1f378","d4ecacc3.36cc68"]]},{"id":"be0d6ac0.c1f378","type":"mqtt out","z":"ff997979.d294b8","name":"","topic":"APC","qos":"2","retain":"","broker":"1425f6c7.b9ea79","x":750,"y":120,"wires":[]},{"id":"d4ecacc3.36cc68","type":"debug","z":"ff997979.d294b8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":180,"wires":[]},{"id":"b4aed1aa.aec878","type":"debug","z":"ff997979.d294b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":450,"y":220,"wires":[]},{"id":"cb1c6661.c219d","type":"function","z":"ff997979.d294b8","name":"UPS_Load","func":"msg.payload = Number(msg.payload.ups_load);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":750,"y":280,"wires":[[]]},{"id":"bd434a78.e3c448","type":"function","z":"ff997979.d294b8","name":"Battery Status","func":"var Vbats = msg.payload.battery_voltage;\n\nvar Vbat = Vbats.replace(\"_\",\".\");\n\nmsg.payload = Number(Vbat);\n\nreturn msg;","outputs":1,"noerr":0,"x":740,"y":360,"wires":[[]]},{"id":"c3d3cefd.564dd8","type":"function","z":"ff997979.d294b8","name":"V IN","func":"var Vins = msg.payload.input_voltage;\n\nvar Vin = Vins.replace(\"_\",\".\");\n\nmsg.payload = Number(Vin);\nreturn msg;","outputs":1,"noerr":0,"x":770,"y":600,"wires":[[]]},{"id":"42e0e523.4e45f4","type":"function","z":"ff997979.d294b8","name":"Bat Runtime","func":"msg.payload = Number(msg.payload.battery_runtime);\nreturn msg;","outputs":1,"noerr":0,"x":750,"y":440,"wires":[[]]},{"id":"fbdb99d8.a26208","type":"function","z":"ff997979.d294b8","name":"Bat Charge","func":"var Vcharges = msg.payload.battery_charge;\n\nvar Vcharge = Vcharges.replace(\"_\",\".\");\n\nmsg.payload = Number(Vcharge);\n\n\nreturn msg;","outputs":1,"noerr":0,"x":750,"y":520,"wires":[[]]},{"id":"1425f6c7.b9ea79","type":"mqtt-broker","name":"MQTT","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
So I would like to use the info of the UPS_Load, Battery Status, Bat. Runtime, Bat Charge and V In, but I'm not getting there.
I already tried other ways to get there, but without any success.
I know, that this is easy for the majority of the users, but I'm stuck here...
Thanks in advance,
Tete
