My flow:
[{"id":"9cd9fa2d0d2e7202","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"13d41ac132368021","type":"server-state-changed","z":"9cd9fa2d0d2e7202","name":"Switch on?","server":"c74ca316.14c28","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["input_boolean.nachtladen"],"substring":[],"regex":[]},"outputInitially":true,"stateType":"habool","ifState":"true","ifStateType":"bool","ifStateOperator":"is","outputOnlyOnStateChange":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[],"x":140,"y":60,"wires":[["6421274bc1d0d573"],[]]},{"id":"dd741507cc53cd34","type":"api-call-service","z":"9cd9fa2d0d2e7202","name":"Take action","server":"c74ca316.14c28","version":7,"debugenabled":false,"action":"input_number.set_value","floorId":[],"areaId":[],"deviceId":[],"entityId":["input_number.charge_current"],"labelId":[],"data":" {\"value\": 10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"input_number","service":"set_value","x":650,"y":140,"wires":[[]]},{"id":"6421274bc1d0d573","type":"api-call-service","z":"9cd9fa2d0d2e7202","name":"Pause charging","server":"c74ca316.14c28","version":7,"debugenabled":true,"action":"easee.action_command","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"device_id\":\"276dadb4c47eea642a878ea0a71bea42\",\"action_command\":\"pause\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"easee","service":"action_command","x":320,"y":60,"wires":[["da034f7d41e777b3"]]},{"id":"da034f7d41e777b3","type":"time-range-switch","z":"9cd9fa2d0d2e7202","name":"Is it specific time?","lat":"","lon":"","startTime":"13:40","endTime":"13:41","startOffset":0,"endOffset":0,"x":590,"y":60,"wires":[["dd741507cc53cd34"],[]]},{"id":"c74ca316.14c28","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
I made a simple flow but it doesn't work.
I have a switch. When it on, I trigger my flow, first it pauses my charger, this works, when I reach a specific time (00:05 at night) it should start my charging again.
I tried the flow by changing my time (not 00:05 but few minutes after I hit 'deploy'.
What I see is that after the 'Time Range Node' nothing happens.
What's wrong?
Thanks for your input!
